Antena adjust.
Antena adjust.
all what appear was cb radios antenas in the search. The base where the antena mounts its getting loose. Do i have to remove the fender to adjust it? Its a 88 Pickup sr5. Thanks guys in advance!! ps im trying to figure how to upload pictures...
One more thing, when i turn the High light, the lights will go of but I just flash they work. The low lights works fine. Any clue on this? it cant be fuse because the hi function when I flash.
- http://www.4crawler.com/4x4/CheapTri...acement/1.html
Or the bolt inside the fender may be loose:
- http://www.4crawler.com/4x4/CheapTri...acement/5.html
An update, the mast of the antenna is broken and I try to fix the high lights, but dint work. Would be better to replace the antenna with a aftermarket one with a low profile or should i buy just the mast or an complete used antenna in ebay?
u can do a mask but when u go 4wheeling u could end up busting it off if u forget to turn off the radio, and with the headlight u might just need to replace the whole combo switch.
I can't tell any difference. The truck never had an antenna from when I got it. I had tried to mount it to the fender, and hated the way it wanted to lean out to the side. So I got this bright idea, and haven't had any complaints.
yea you dont wanna break an antenna off. it sucks. goota replace the whole thing, unless you can find a way to get the threaded part out, i tried EVERYTHING i could think of. and dont buy one of those autozone ones if you want it on the fender. pissed me off so much cause it leaned so i layed it across my dash for like a month till i got a toyota one. friggin narrow trails!
