another question, block markings
Old 06-04-2008, 04:33 PM
76ANTHONY's Avatar
got the whole engine torn down and found the bearings ummm a little trashed and im going to replace them, but before i do, im looking at the rear of the block on the surface where the oilpan goes and its marked with 2 2 2 2 2 2, what does this mean? does it mean i have #2 bearings? i tried measuring everything with my telescope bore measurer but its not perfectly acurate....
Old 06-04-2008, 05:35 PM
76ANTHONY's Avatar
found out that my rods are all marked as #2 bearings and i found a way to measure them correctly. now to go measure the bore
Old 06-04-2008, 05:54 PM
HAVOC's Avatar
Check out the chart at the bottom of EG2-104 http://personal.utulsa.edu/~nathan-b...ne/69cylin.pdf. When you buy the rod/main bearings at the dealer they ask you what number they are. Use the chart to find out. This is helpful if you plan on using a crank from another engine (like I'm going to do).
bigjstang
08-25-2021 12:41 AM
TJWilly
07-31-2015 02:05 PM
thefishguy77
07-30-2015 10:59 AM
jon.r
07-11-2015 03:34 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: another question, block markings
