another knock sensor wire. quick question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2009, 07:58 PM   #1 (permalink)
weakyota91's Avatar
my 3vz-e needs a new knock sensor wire just a quick question as to wether or not the timing belt or water pump need to be re-moved to get the lowerer intake manifold off. Thanks guys and any other helpful guidance
__________________
1991 extended cab
3.0 v6
5" trail-gear sas swap
63" chevies in rear
35x12.5 goodyear mtr's
4:88 gears with trutrac front, locked in rear
warn m8000 w/arb front bumper
marlin crawler rear bumper
flowmaster 40 series
weakyota91 is offline
Old 11-08-2009, 08:27 PM   #2 (permalink)
bugs1961's Avatar
The timing belt needs to be loosened so the upper idler pulley can be removed. The water pump can stay, unless it's time for a timing belt/water pump change anyway. Carefully following the FSM will be important as there are quite a few steps. Take some photos before you begin from as many angles as you can, especially the vacuum hoses on the passenger side of the plenum.
__________________
'89 V6, 5 spd truck and '07 FJ Cruiser
bugs1961 is offline
Old 11-09-2009, 04:50 AM   #3 (permalink)
Team420's Avatar
the first time you get in there can be a bit daunting, but it really isnt that bad...
heres a tip.... instead of pulling all the hoses and such from the upper plenum, just leave what u can attached, and flop it over the fender....makes life a lot easier. Also...if ur going to be in there any way...I would seriously suggest replacing the sensor itself. I had the same issue, and just replaced the pigtail, and it didnt fix my problem, I then had to go in again, and replace the sensor, which still didnt fix my problem, but would have been nice to know it was new instead of having to rip into it all over again.
My problem ended up being a vacuum leak.......
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 233k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 235k on the clock.
It's becoming an addiction.
Team420 is offline
Old 11-09-2009, 09:27 AM   #4 (permalink)
weakyota91's Avatar
yea thats my plan is too just flop over the manifold. i had the head gaskets replaced in 04 along with the knock sensor from toyota (180 dollars for sensor) and the wire i bought got left in my toolbox and never given to the mechanic so im just gonna change the wire. I dont see why the sensor would be bad. its kinda weird my cel light is off every time i start my truck no code stored or can be pulled until i either rev past 4 grand in 1st gear while driving or shift into second and give it gas. i can be out wheelin and if i start it up and stay in 1st or going down hill for 5 minutes and no cel but if i shift into 2nd it pops on with code 52
__________________
1991 extended cab
3.0 v6
63" chevies in rear
Old 11-09-2009, 03:47 PM   #5 (permalink)
Team420, you had a vacuum leak cause a code 52?
Where was your leak?
James64 is offline
Tags
3vze, knock, replace, sensor, to, wire, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
