Another CV Boot Thread
Old 07-10-2008, 05:18 PM
sneakysnake's Avatar
Ok, before everyone tells me to use the search tool; I have, and I couldn't find what I was looking for...which is an easy to follow guide using somewhat lamen(sp?) terms. All the other threads I've found on the subject use terms that I have no idea what they mean.
So, onto where I am now: you can really see where I am now, what you may not be able to see is that I have already removed the c-clip and washer behind it. This is the point where I'm not sure what to do next.
So, if you could help me out with this I would much appreciate it.
Andrew
Old 07-10-2008, 05:59 PM
kipres's Avatar
re move the gland nuts (2) then it will be free to remove
Old 07-10-2008, 07:45 PM
76ANTHONY's Avatar
just did this last night on my 90, what a pain in the azz. it sounded so easy, till ya cant slide the sob between the shock and stab bar area
Old 07-11-2008, 04:10 AM
Yeah, I have absolutely no idea what a gland nut is or where to find it.
Old 07-11-2008, 04:30 AM
blueyoda's Avatar
OK so you are removing the cv to replace the boot? Unbolt the cv from the front axle flange( the 6 bolts on the inside end of the cv). REMOVE THE SHOCK, this will make the job 100% easier. You don't have to remove the top nut, just romve the bottom bolt and swing the shock out of the way. Pull the cv away from the axle flange(with the six bolt) and let the back drop down and slide it out. you don't have to remove any more bolts, the spindle(end of the cv with the splines on it) should move freely inside the hub and out it goes. reverse steps for installation and be sure not to damage the lip of the cv that butts up against the back of the bearing assembly(brake rotor and such). This is the inner sealing surface and is very touchy, a little dent or bend and the cv retaining snap ring will not seat if the cv is not TOTALLY in.
Old 07-11-2008, 04:32 AM
blueyoda's Avatar
Oh yeah, while your at it install some manual hubs and you will have to do this A LOT LESS.
Old 07-11-2008, 04:35 AM
bigt's Avatar
use my 2 jack method that someone hooked me up with on here and it takes like an hour!
Old 07-11-2008, 04:49 AM
blueyoda's Avatar
A jack under th lower a arm is definatly handy for reinstall, good point t.
Old 07-11-2008, 06:25 AM
Awesome, thanks guys. After I get off work I'll be getting right on this.
Old 07-12-2008, 10:08 AM
Got the passenger side done, when I do the drivers side I'll take pictures as I go along to help out others with step by step pics.
Old 07-12-2008, 10:17 AM
bigt's Avatar
easy with 2 jacks next time i gotta do one i cant wait
Old 08-01-2009, 05:01 PM
klbeans's Avatar
Sorry for bringing this thread back to life... but I am using the SEARCH feature and found this thread.
What's this 2 jack method you speak of? I did a search and didn't net out with anything.
Old 08-01-2009, 06:53 PM
nevermore1701's Avatar
Put a jack under the opposite rear frame from the CV you're changing, and another under the A arm of the one you're changing. Gives you a bit more clearance, and coupled with disconnecting the bottom of the shock, should be enough to slide it out without too much trouble.
Old 08-02-2009, 09:04 PM
klbeans's Avatar
Ah. Thanks for clarifying.
Old 08-02-2009, 10:41 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
When I did mine. I removed the bolt holding the front diff, and jacked up the diff. Had both mine CV replaced in under 4 hours.
icentropy
09-16-2020 02:47 PM
ia02
08-20-2015 11:04 AM
bobjohnson2121
08-18-2015 06:17 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
Quick Reply: Another CV Boot Thread
