Another brake upgrade/repair question
I wanna start by saying I'm not just posting without searching.
Issue, my calipers are old rusty and now sticking. When I'm at speed and hit the brake the truck turns right pretty hard. Only one hand on the steering wheel? You are practically in the next lane after breaking.
However, I'm trying to figure out if I should just replace the calipers with the same or go for an upgrade. The reason I'm asking is I have an 88 v6 4runner. I've read some threads which seem to lump these in with t100s, and others that consider them 1st Gen 4runners and need to be upgraded. Trying to figure out what is ground truth.
Since this truck used to be a 3.slo, does that mean my master needs to be upgrade too, or is not necessary?
My intention is keep it all Toyota and not do the stuff I saw on pirate (ericb?). Just a personal preference...like the 3.4 swap. Just wanted to keep it Toyota truck where the choices were basically a coin flip.
Thanks
Thanks
Do you find your brake performance lacking when everything is working like it should??
I have never seen any real world numbers on these so called upgrades .
Just claims of replacing old worn out parts with brand new .Then Wow the brakes are so much better
Just know the caliper upgrade might not work with the steel wheels
I have always keep the brakes up to my standards with no problems.
Don`t forget the rubber hoses .
Im with you. Can lock my wheels with the regular brakes, so what are you gonna upgrade? All these calipers need some loving every once in a while because of how they work. 4 pistons need to move together unlike other cars with a slider. Im in canada and need to rebuild them every 2 years or so due to the rust seizing them.
You can get the rebuild kits from Rock auto. Easy job.
Not much for you to upgrade. V6 should have larger Pistons in calipers. You can upgrade the rear wheel cylinders but have to modify shoes to fit. If you were happy with them before just replace them. Your master cylinder should be 1" too.
I noticed as I went up on tire size that the upgrading was of interest to me.
i'd suggest replacing the front hoses as well.
Staff
I use an air hose and flush the brake lines out and then let some Marvel Mystery Oil set in the lines for a few days and flush again. You will get all kinds of rust and gunk out of the lines when you do that. I remove the line from the master cylinder and slave cylinders/calipers and blow thru it that way.
If I recall right my brake job on my 85 cost me $250 for everything new/rebuilt from my local parts store and that was with new front wheel disc, master/slave cylinders, calipers, pads and shoes. I had my rear drums turned. My truck will stop straight and put you in the windshield if you stomp on them. My hoses were in great shape so I did not need to mess with them.
FS[MidWest]: 1987 turbo truck 22rte 5speed 4x4
justin smith
06-16-2016 12:16 PM
FS[SouthEast]: 96 4runner limited 5 speed swap
hektikwon
05-06-2016 07:16 PM
