Another 3VZE rough \ low idle in gear only - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-31-2006, 11:28 AM   #1 (permalink)
I have a 95 v6 auto 4runner. In park or neutral it idles just fine. When I put it into gear the idle drops to around 500rpm and it is very rough. It also seems to miss \ stumble all the way upto about 1500rpm. I've had it about 7 months and have replaced the; spark plugs, plug wires, cap, rotor. I have also cleaned out the throttle body. The truck was running fine after I did all of this work, however just the other day this new behavior began. My guess is TPS but I'd like to hear from some people smarter than me first.
Thank you all in advance,
Cheers - Josh
josho is offline
Old 07-31-2006, 12:07 PM   #2 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
Find all the answers you'll ever need...
I would guess TPS too.
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 07-31-2006, 02:37 PM   #3 (permalink)
Tdubbs05's Avatar
haha yeah check that out. i'll make it easy on you and give you one thing that might be able to fix your problem. try turning the flathead screw on the top of your intake manifold. right hand side on the very top. about a .5 inch flathead screw that you turn while it's on. try adjusting it till it feels good. should be a little higher than 800 rpms. anything lowere gets a little rough
Tdubbs05 is offline
Old 07-31-2006, 03:11 PM   #4 (permalink)
Quote:
Thank you for the idea, I have adjusted the idle and it idles fine until I put it into gear. So I don't think that's the sollution. I've done a lot of searching and it seems like TPS is my best bet so far.
josho is offline
Old 08-01-2006, 04:14 PM   #5 (permalink)
#5 plug wire was arching. Replace plug wire and it's good as new again. Thanks for the replies.
josho is offline
Old 08-01-2006, 08:34 PM   #6 (permalink)
workinprogress's Avatar
how did you test the wire to find the arc?mine is identicle to your problem,and i have tried the same things to fix it,but with no luck.I figured i could test the wires and see what happens.thanks
workinprogress is offline
Old 08-02-2006, 03:24 PM   #7 (permalink)
I looked under the hood in the dark and could see the spark against what I think is part of the EGR valve. It looks like there used to be a plastic piece that held the plug wires away from it. I think the contact with the hot metal melted the insulation exposing the wire.
josho is offline
Old 03-22-2007, 06:22 AM   #8 (permalink)
jbyrdman's Avatar
Send a message via AIM to jbyrdman
I'm having identical problems, when you accelerate did your exhaust sound like it was some kind of air compressor to about 1500 rpm, mine does sounds like puffs of air are coming out of the exhaust, also my gas mileages has gone to none, 100 miles on 1 tank! Just got this 4runner two weeks ago, don't even have the tags on it. Please help!!
jbyrdman is offline
Old 03-23-2007, 05:47 AM   #9 (permalink)
jbyrdman's Avatar
Ok, I HAD identical problems, last night I check the TPS, the O2 sensor the MAF, did a cylinder drop test and found no change when I pulled no. 3 wire, pulled the plug and was getting a good spark, put it back checked the fuel injector for said cylinder and it was fine. I was getting ready to take it to the dealer to have them look for a burnt valve, when my wife came out and tripped over the plug on the shop lights I had set up, (it was 1am by this point), then I saw a beautiful blue flashing light.....I guess with identical problems I should have checked the solution for that problem. no 3 was arching on the egr valve, same plastic piece was melted. Taped the melted wire, wire tied it away from the valve, and its running like brand new!! Thank God!!
jbyrdman is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Extremely Low & Rough Idle on 22re Auto hub_01_69 86-95 Trucks & 4Runners 21 11-17-2006 02:55 PM
very low idle and rough with 3.0 faubrunner64 86-95 Trucks & 4Runners 4 09-01-2006 09:17 AM
Rough idle at low RPM after carbon cleaning... help please... YotaJunky 95.5-2004 Tacomas & 96-2002 4Runners 4 03-01-2005 09:00 AM
3vze Rough Idle and Exhaust Gurgle whays 95.5-2004 Tacomas & 96-2002 4Runners 5 09-18-2004 06:18 PM
Low/Rough idle tpg013 95.5-2004 Tacomas & 96-2002 4Runners 1 11-26-2002 10:53 AM
2009 InternetBrands, Inc.
