another 22re motor ?
as i begin my search to find a new motor for my 89 truck I soon realized there is a shortblock and a longblock 22re.Whats the difference???Confused
Typically it's set up like this:
Short Block:
Lower Block, Crankshaft, Connecting Rods, Pistons, Rings, Main Bearings, Rod Bearings, Cam Bearings, Camshaft and Timing Set occasionally.
Long Block:
Lower Block, Crankshaft, Connecting Rods, Pistons, Rings, Main Bearings, Rod Bearings, Cam Bearings, Camshaft and Timing Set, Lifters, Gaskets, Cylinder Heads, Valve Train, Oil pump and sump. You typically have to do the cleaning, rebuilding and reassembling of components like your oil pan, timing chain cover, valve covers, induction system, electronics, pulleys etc. back onto the engine.
Short Block:
Long Block:
It's much easier to buy a complete engine and just pull your old one out and drop the new one in. You are going to pay a little more, but it saves you time and frustration.
Rob
Rob
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
