Alternator vs battery question
Old 11-09-2010, 10:23 AM
rovers1973's Avatar
Just a quick question about my 91 pickup 3VZE. I was on my way to work today, and the dash lights started dimming while the turn signal was on. Turned on the heater and the dash went right down for a 1/2 sec and back on. Get to work and turn it off. Tried to start it again and not even enough power to turn it over.
Question: If its just the battery that's toast, will it run just off the alternator if I jump start it? My meter and tools are all at home and I have no way of testing anything here.
I'm guessing if the alternator has packed it it, it won't even jump start since the battery is now drained.
Oh, and did I mention its cold and raining outside too. Fabulous.
Thanks guys.
Old 11-09-2010, 10:45 AM
rovers1973's Avatar
Originally Posted by razed
jump start should put sme juice in the batt so it might start
it might not keep running after that if the alt is not charging
So, if it does stay running, but the battery won't hold a charge, replacing that should fix it. I'm just curious if the battery is only necessary for starting, and once its running, does it all run off the alternator?
redneck17
10-29-2015 09:09 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
stock87yota
07-31-2015 10:08 AM
80Truck
07-24-2015 03:12 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Alternator vs battery question
