alternator questions??
Old 03-23-2010, 09:55 PM
db8gsr's Avatar
I was having problems with my alternator awhile back on my 94 4x4 toyota pickup v6, so i replaced it:everything was fine for awhile, but now the problem has returned. the little bolt on the side of the alternator that runs to the battery keeps sparking and is even melting the bolt.
i followed that wire and it runs to the positive terminal of the battery.Im thinking that maybe it's suppose to be hook up to the negative, but i wanted to ask the experts before i electricute myself. If i have it hook up right can someone shed some light on some solutions. thanks-a-million
Old 03-24-2010, 08:20 AM
db8gsr's Avatar
anyone???
Old 03-24-2010, 08:30 AM
toyrunnerns's Avatar
it might be loose or corroded.
Old 03-24-2010, 08:37 AM
db8gsr's Avatar
but is it suppose to be hooked up to the positive or negative? can someone pop there hood and check for me plzz
Old 03-24-2010, 09:06 AM
OutlawMike's Avatar
This bolt? The one under the orange cover in this photo? If so, it is supposed to run to the positive terminal of the battery via the 80 amp fuse in the fuse block.
The grounding for the alternator happens back through the engine block.
Do not hook that wire up to the negative side of the battery, bad things will happen.
Picture:
Old 03-24-2010, 10:30 AM
db8gsr's Avatar
thanks^^ ok so it is hooked up right.i wonder why its shorting out?
Old 03-24-2010, 11:46 AM
OutlawMike's Avatar
As said above, loose or corroded would be the first place to start.
redneck17
10-29-2015 09:09 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
RBK
08-02-2015 11:33 AM
80Truck
07-24-2015 03:12 PM
msane99
07-17-2015 10:13 AM
Quick Reply: alternator questions??
