Alterations for 33's
Old 09-28-2011, 07:15 PM
Decker's Avatar
Hey guys, i have a pair of 33 x 12.5's and i want to put them on my stock 94 4runner. What can i do to make em fit (without rubbing) without getting a lift. Also, if a lift is definitely needed, what kind should i get and where can i get it for cheap.
Old 09-28-2011, 07:45 PM
Stuwy123's Avatar
Hammer the pinch weld really good.
You'll need to take computer out of the passenger side kick panel before you do any heavy hammering.
You'll need to trim the bumper and valence.
Move the back mudflaps behind the steel support.
Take off the front mudflaps.
Lots of test fitting.
Old 09-28-2011, 08:07 PM
Drunner's Avatar
2 inch body lift if you dont want to hammer or cut.
Old 09-28-2011, 08:11 PM
Decker's Avatar
I have never done a body lift nor do i know anyone who has. How complicated is the install and what modifications might i need to do that are not included in a body lift kit?
Old 09-28-2011, 08:25 PM
rhill's Avatar
http://4crawler.com/4x4/ForSale/BodyLiftKit.shtml
search more for info on 33s, I know I've seen some guys who fit em with no lift. most say you can fit 33x10.50 with no trimming reqd.
Old 09-28-2011, 09:05 PM
4Crawler's Avatar
Specifically see the section of the page below:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Has info on both the fender trimming and other options. A lot depend on the wheel/tire combo as width and wheel backspacing are both important.
Old 09-29-2011, 07:13 AM
Decker's Avatar
4crawler
The site said I could do a 1.5" ball joint spacer and a coil spacer...would I need to extend any steering, shifter, brakeline with a lift like that?
Old 09-29-2011, 07:17 AM
vasinvictor's Avatar
I run them with ZERO lift on a 4" BS wheel, hammered pinch weld ZERO rubbing on the trail. Had to trim the front plastic valance a hair too.
Old 09-29-2011, 07:23 AM
4Crawler's Avatar
Originally Posted by Decker
4crawler
Generally not:
- http://www.4crawler.com/4x4/ForSale/...er_HowTo.shtml
- http://www.4crawler.com/4x4/ForSale/...l#Installation
Again it will still depend on the wheel specs.
Old 09-29-2011, 09:27 AM
tj884Rdlx's Avatar
i definitely endorse 4crawler's 1" body lift kit. it's added a little bit of clearance in a bunch of critical areas where wrenching would be tight, in addition to the benefit for tire clearance.
remarkably easy to do as well if you pre-soak your bolts a day in advance. with just a floor jack i was done within an hour.
Old 09-29-2011, 10:37 AM
Decker's Avatar
Again, on the 1"lift, do I need extend the steering or brake line or should i be okay
Old 09-29-2011, 10:57 AM
bob200587's Avatar
And this isn't in the newbie tech section because.....?
Old 09-29-2011, 01:10 PM
angrybob's Avatar
Already answered below.
4crawler
Generally not:
All the info you will ever need to know about body lifts is there...including necessary extensions and when they are needed. You gotta read a little.
Old 09-29-2011, 01:30 PM
BMcEL's Avatar
There is an entire thread dedicated to this question.
https://www.yotatech.com/forums/f177...thread-169234/
mrj_inc@shaw.ca
12-10-2007 11:00 PM
DiskDoctr
07-24-2006 01:23 PM
redtoy92
12
09-08-2004 04:50 AM
Quick Reply: Alterations for 33's
