Alt. light flickers
Alt. light flickers
I noticed every once in a while my alt. light flashes real quick at idle. The engine doesn't miss, aftermarket volt meter reads over 14 and doesn't flicker. It will just flash maybe once a minute or not at all. It is so quick I had to deliberately sit and watch it to see what the light said. '88 DLX 3.0 5spd
Could also be a ground issue. The wiring, harnesses & connections/connectors are all getting old & brittle. Check all the major grounds (ECU, fusebox underhood, frame, engine, body, etc.).
Probably not (but you just determined that yourself!) An "automotive" voltmeter has lots of damping, if for no other reason than to keep the needle from jiggling on rough roads. I would be surprised if it reacted fast enough to catch anything you'd call a "flicker."
ashersullivan88yota
01-18-2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
