Aisin Manual Hubs Stuck to Axle
Old 02-08-2011, 05:17 PM
NW-Yota's Avatar
As the title says my aisin hubs are stuck to the axle, the PO really messed them up by not putting a gasket on them. Un-beknownest to me so lots of dirt and water got in there. They finally seized up in the "lock" position so i decided to replace them. I can get the dial off but not the body of the hub. My question is, are they not coming off because they are in the locked position? Or do i need to lift the front end of the truck off the ground to take them? Or am i missing something else? Any responses would be appreciated, i wont respond till the morning though i gotta be up for work at 3 and i already ingested a sleeping pill FML
Thanks!
Old 02-08-2011, 05:24 PM
xxxtreme22r's Avatar
did you remove the center bolt and take out the guts of the hub? You should have.
Old 02-08-2011, 06:07 PM
mightymouse's Avatar
take out the cone washers? Search on ifs hub removal before posting?
RustBucket's Avatar
Cone washers stuck? Search cone washers for a multitude of methods for removing them.
Old 02-08-2011, 06:08 PM
RustBucket's Avatar
LOL beat me to it
Old 02-09-2011, 03:01 AM
peow130's Avatar
Cone washers like everyone said, or the whole hub is siezed together from rust.. a small chisel can help with this. But don't go crazy.
Old 02-09-2011, 12:40 PM
NW-Yota's Avatar
Thanks guys, it wasnt the cone washers. Those came out fine. Im gonna try and tackle it again this afternoon. Thanks for the link Wabbit ill see if i can find the solution in there. But one last question... Is it possible the reason they arent coming out is because they are seized in the lock position?
thanks again
Old 02-09-2011, 05:28 PM
NW-Yota's Avatar
Sorry guys finally figured out, i had no idea what a snap ring was let alone snap ring pliers. That was definitely the problem. Thanks Homeless!
Old 02-10-2011, 09:14 AM
peow130's Avatar
Snap ring only holds the CV in place.. the bolt on ifs rigs holds the locking mechanism to the hub itself.
Did you remove the entire bearing from your hub?
oldirtydirt
02-23-2020 09:30 AM
jaretstuff
08-04-2015 02:08 PM
MTLroadierunner
07-20-2015 03:07 PM
PlayAwhile
07-20-2015 11:36 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Aisin Manual Hubs Stuck to Axle
