aisin hub turns to lock cv's dont engage
Old 01-09-2011, 03:16 PM
hunter h's Avatar
Alright so I gotta 94 p/u aisin hubs. They never been romoved my dad bought it brand new so i know they havenn't been touched. The passenger side will lock and unlock by hand but not easily but will not engage. Wanna take them apart tomorrow (in the snow if I have to) lol. I read around the forums about how to do it but what should I look for as far as damage goes?
Old 01-09-2011, 03:18 PM
waskillywabbit's Avatar
Follow my write up. Probably full of gunk and just need cleaning and regreasing.
:wabbit2:
Old 01-09-2011, 03:35 PM
muddpigg's Avatar
X2 when mine did it just needed cleaning and lite greese
Old 01-09-2011, 03:39 PM
slacker's Avatar
check for a broken spring
(inside the hub)
Old 01-09-2011, 05:06 PM
hunter h's Avatar
That's good to hear. Hopefully it just needs a cleaning. No money for new ones right now. Lockers just took my wallet for this check. Thanks guys
Old 01-13-2011, 12:58 PM
hunter h's Avatar
Ok took hubs apart and stripped down. Nothing broken just rusty and gunky. What's the best way to clean?
Old 01-13-2011, 01:12 PM
camo31_10.50's Avatar
uhm, just get all the grease off, i threw mine into a parts washer for a bit, then i media blasted the outside of the body and the hub dial and face.
Old 01-13-2011, 01:16 PM
hunter h's Avatar
The outside of the hub body is good. The clutch and pawl hand I think its called has some surface rust tho wire brush not doing much. Maybe after a parts washer dip it will
Old 01-13-2011, 01:19 PM
fierohink's Avatar
a toothbrush and some degreaser sprayed in to a cup. or use a parts washer if you have one of those.
Old 01-13-2011, 01:43 PM
TMP
TMP's Avatar
Your prolly gonna need new orings and gaskets when you put them back together. I got mine at a local Toyota dealer for like $20.
Dial cover 43531-60010
Hub body 43422-60010
Oring under dial 43532-60010
Old 01-13-2011, 06:11 PM
hunter h's Avatar
well parts washer is out my buddy had one but said its gone now so i guess try your method fierohink. see it that works. and yea ill prob get those from wab if i replace. which i prob will
muddpigg's Avatar
Look for the detent ball and spring on the dial face. Mine had rusted up.
Old 01-13-2011, 06:23 PM
Soak them in mineral spirits or some degreaser overnight and then clean with a tootbrush. Wipe clean. Clean up rusty spots with a Dremel tool with a wire brush.
Light grease to reassemble. I got a thread how to do that on here.
:wabbit2:
Old 01-13-2011, 06:33 PM
jsn_stockard's Avatar
I would grease the spindle bushing while I had it tore down. There is plenty of info on that here as well. X2 on supporting a vendor, check out Wabs site, link in his sig.
Old 01-13-2011, 08:40 PM
hunter h's Avatar
yea my ball and spring are a little rusted gonna try to clean it up if not wab will get a order. good idea on the dremel. i have read your your thread on the reinstalling wab. thanks guys. my hubs have been off for two days now should i be worried about moisture getting to the parts exposed on the truck
deepmarsh
08-06-2015 03:44 AM
MTLroadierunner
07-20-2015 03:07 PM
PlayAwhile
07-20-2015 11:36 AM
1996Taco
07-20-2015 12:02 AM
Steven.m.paulk
07-13-2015 01:40 PM
Quick Reply: aisin hub turns to lock cv's dont engage
