AIR COMMING FROM VENTS... Help!
Old 05-24-2007, 12:37 PM
keithguts's Avatar
OK my problem is, everything is off, and when I drive, air is comming out my vents. Any idears of why?
My rig is a 1995 4 runner..........
Old 05-24-2007, 12:39 PM
gilby4runner's Avatar
the systems allow fresh air to come in while driving. Does it still circulate while you are stopped?
Pest's Avatar
I don't know of any vehicle that doesn't have air coming though them while at speed with the fan off. I mean, it's a vent connected to the outside, I'd think that's normal. All my vehicles do that....
Old 05-24-2007, 12:41 PM
Blurr's Avatar
flip the lever to recirculated(cabin) air and see if the airflow stops while driving.
Old 05-24-2007, 12:42 PM
keithguts's Avatar
No, only when I drive. I don't remember it ever doing this before.
Old 05-24-2007, 12:44 PM
KevinInSac's Avatar
X2 on that. I like to have is on fresh air while I'm cruising just for that reason. It lets a little bit of air flow in, but not a whole lot. Kinda like a super low speed.
Greg_Canada's Avatar
Mine does this too as it gets warmer outside.
It's perfectly normal.
If you dont want it coming in, change the air switch from fresh to recirculate.... as previously mentioned.
dijlop's Avatar
yea, im pretty sure its normal. u may have never realized it b4, or maybe ur vents have never been pointed at u in a way that made it so u could feel it, but air usually flows through. certainly isnt a big problem or anything, right? i mean ,who doesnt want fresh air from outside?
Old 05-24-2007, 12:48 PM
keithguts's Avatar
Ya, I guess I just never noticed is as you said. Just making sure it is the way it should be working. Thanks all................
Old 05-24-2007, 12:50 PM
surf4runner's Avatar
you can also switch it from room to def or ??? so it flowing through diff spots
GM TURBO's Avatar
If you don't like it - put the lever to recirculate.
06-01-2021 01:51 PM
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
karbin
07-05-2015 11:37 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: AIR COMMING FROM VENTS... Help!
