AHHHHHHHH! 88 pickup 22re Coolant on the passanger floor...
BLAHH!!!!!!!!! coolant on the floor and it keeps over heating. SO the heater core is bad correct?
1. How big of a bitch is it to get to in my pickup?
2. Anyway i can stop the leak without replacing the core. Is it a bad line?
it will be a pain in the ar$e but it will not be that bad you will have to remove the dash.
https://www.yotatech.com/forums/f116...umbers-102344/
yeah basically. its not the easiest thing to do, but once the dash is off its not too hard. just remember where everything went or you'll be like me.. spending 20 bucks on a repair guide that should have been used in the first place just to not be able to read it and guess where stuff went. works ok, but wont be the same.
It COULD be just a line going to or from the heater core. So, check that first. But, if it is the core, take pictures while you're disassembling and keep track of all your fasteners. Easy buggers to lose.
I second taking pictures... im doing a 95 sunfire right now actually... gonna finish the rest in the morning and its a terrible job and i wish i had taken pictures... iknow im getting sumwhat creative putting it back together
i just replaced the heater core on my '94 the other day. it was pretty straight forward. (though, my previous experience was with my supra, and there are a lot more wires behind that dash, heh)
all in all, not a bad job. if anyone needs pics, i took some between beer, food, and helping my friend replace the rotors, calipers, and pads on his '91.
-shaeff
-shaeff
Heater Core
Just start early and do the whole job the same day and your memory should make the trip , havn't done one on the Yota yet but on my SLS 4WD Jimmy , same deal had to drop the steering column and pull the entire dash out , took all day but got it done ...............Git er Done .
Avenged
07-09-2015 07:55 AM
