YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 08-13-2007, 08:35 AM   #1 (permalink)
Personal Sales Rating: (0)
Aftermarket temp gauge sensor location 22re?
I searched and I am not 100% sure were to put the aftermarket temp gauge sensor. I don't want to mess up the ECU by removing a sensor that it needs. Is the correct location on the intake manifold between the 2 ports?
__________________
2006 Specialized Rockhopper bike.
co4rnr is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 08-13-2007, 08:59 AM   #2 (permalink)
ewong's Avatar
Quote:
Yup - thats the one used by the instrument cluster.
Other option is to get a thermostadt outlet from a 22RTE - theres a boss on there - but of couse it measuers the water temp AFTER the thermostadt...
ewong is offline
Old 08-13-2007, 09:41 AM   #3 (permalink)
Threadstarter [OP]
Sweet! Thats were I will put it!
__________________
co4rnr is offline
Old 08-13-2007, 10:43 AM   #4 (permalink)
ewong's Avatar
just to clarify
Ont he 22RE there are THREE temp sensors that Im aware of
TWO are used for the EFI
These are located on the forward part of the EFI manifold and poitn towards the radiator. The connectors have more than one pin in them and have small O rings etc.
The one use by the instrument cluster is in the intake manifld by the #3 intake. It has a small "spade" type connector and the connector points "up" towards the hood. Its grounded via the engine ground.
ewong is offline
Old 08-13-2007, 10:57 AM   #5 (permalink)
mt_goat's Avatar
Here's another option:
Click the image to open in full size.
It reads within 5 degrees of my OBDII scanner there.
__________________
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG KM2, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, TJM T-17, Warn m8000.
mt_goat is offline
Old 08-13-2007, 11:03 AM   #6 (permalink)
ewong's Avatar
Hey MtnGOat - where did ya get that "maifold"?
Also - as I pointed out - the 22RTE has a "fitting" on the outlet pipe (the 22RE does not) that can be used to do the same thing..
IMHO - it only reads the same AFTER the thermo opens.
I used to run an autometer "low temp" guage in it and you could watch the thermo open and close until the temp balanced out to a steady state
ewong is offline
Old 08-13-2007, 11:50 AM   #7 (permalink)
mt_goat's Avatar
Quote:
Yes, that's true. My thermostat opens right away (160*) and is open all the time after warm-up.
What manifold? If you mean the pipe that the sensor is in, its descibed a little bit here:
http://www.yotatech.com/50531672-post489.html
__________________
mt_goat is offline
Old 08-13-2007, 05:47 PM   #8 (permalink)
ewong's Avatar
Oh
I thought it was a tube with a rolled bead and a welded screw bung... I think Autometer has em but I dunno if they work with Toyota hoses...
ewong is offline
Old 08-15-2007, 07:13 AM   #9 (permalink)
rdlsz24's Avatar
Send a message via AIM to rdlsz24
You can see in this picture I installed an aftermarket sensor on the manifold when I had it apart to replace my headgasket last winter. Pay no attention to the red box lol.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd)
Rancho lift w/ 33x12.5x15 tires & 5.29s
- SOLD January 2010 -
rdlsz24 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
1990, 22re, aftermarket, auto, automobile, coolant, gage, gauge, installing, location, replacement, sensor, temp, temperature, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Anyone with aftermarket coolant temp gauge mt_goat 86-95 Trucks & 4Runners 15 08-05-2007 04:43 AM
1990 22re temp gauge question scuby22b Newbie Tech Section 1 07-23-2007 10:03 AM
Installing aftermarket eng temp gauge on 3.0. suprathepeg 86-95 Trucks & 4Runners 12 11-08-2006 07:14 AM
Location of air intake temp sensor 1990 3vze?? LOCKnGO 86-95 Trucks & 4Runners 7 07-28-2006 07:56 PM
fault temp sensor, correct gauge? Chuki 86-95 Trucks & 4Runners 1 07-14-2006 02:46 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
