AFM opps :(
AFM opps :(
Ok so i was checking the AFM (should of looked it up first im dumb) well i tried to disconnect it by taking the two screws out the sides and pulled on it well... this was a BIG mistake!!! i tore the wires out of it and it lookes like they were connected directly to the board. can they be re attatched? solderd in or something? I feel really dumb for doing this
here's a link to a high res pic of the AFM board.
Some one on another board did exactly the same thing
In fact when I saw this thread I thought it was a repost.
http://www.ovrrdrive.made2own.com/up.../AFM_large.jpg
I hope this helps
If you need more info go to this thread
http://www.toyotanation.com/forum/sh...&highlight=AFM
I hope this helps
I hope this helps
I hope this helps
Thanks a lot the conenctions got resoldered but the lil metal fins were completly damaged... how important are they? the car runs fine now tho i jsut hope those fins are not going to be an issue..
I hope this helps
I hope this helps
Now you've gone and done it...
Now that you linked that thread here I can't go in and change the pics to goatse to piss off the mods over there.
That forum seems very lame these days...
I did the samething about 4 years ago. Toyota never should have put screws there! Anyway after cutting it open and resoldering the foil strips back onto the circuit board and resealing the lid it worked fine. Just have to get some very thin solder and a small soldering tip and be careful not to overlap any of the tracer lines on the circuit board. One piece of foil I soldered together in the middle of the strip. Good luck
And you are right about the other board
It's definitely ok, don't worry about it.
If I saw it being linked on a board I don't post on I'd go delete the pic though, but it's all good here.
Btw, good to see some of you guys starting to post here more.
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
