Added a center cup holder
It is the heater delete center console (wanted more storage and no leaks), and its actually a cup holder from a Dodge Durango grafted in to the change tray on the Toyota center console. Im super happy having a decent sized cup holder now.
Looks pretty clean. Mind detailing how you went about doing this?
Took my time with the Dremel till i had the bottom of the change tray removed and parts of the sides that pinched the cup holder. took a razor blade to trim down the cup holder sides and bottom of the lip on it. Filled in the gaps with epoxy, sanded smooth for a clean look then dyed black for a uniform finish.
only really took me about 3 hours to complete it, took about two weeks to get all the parts off ebay.
Oh man. I need to do this! Toyota was NOT thinking when they designed these cup holders... The size is fine, for me it's the stability that is the issue.. good think I can drive with only one hand on the wheel.....
Thanks, Droidabuser!
Exactly, Gevo.
Mine's (1986 first-gen) making slow progress... (here)
Need to learn Fiberglas work, if I were to make it look pretty.
Exactly, Gevo.
Also, I have the rear heater which I leave the valve for it cracked open just a tad bit so the antifreeze doesn't sit in the core and eventually harden and clog up like it was before.... which means that area gets pretty warm.... I guess some insulation would help if i get to it.
Nice! Except, putting an open mug in the cup holder.. I imagine you can't really drive that way??
My sound-proofing post shows insulation used on tranny hump, etc.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Highlander Giant
09-08-2015 06:46 PM
justdifferentials
09-05-2015 06:52 PM
