ADD vacuum question
ADD vacuum question
Hello all. I have a 93 That is not cooperating. So it has the add 4wd system and 4wd is not engaging. I have traced the problem to no vacuum from the engagement vsv. My question is, how do I test the vsv and what actuates the vsv? Is it a switch on the tcase?
For all questions, consult The Good Book: http://web.archive.org/web/201204242...26addcontr.pdf
There are two VSVs. Do you have vacuum TO each? The VSVs are driven by 12v; the ground side should be white-black (which you will confirm with your multimeter) and you can run 12v to the "other" side to see if the VSVs work.
The good news is that this part is only $425 (if you get it online; more from a brick-and-mortar dealer) http://www.toyotapartsoverstock.com/...544035010.html So I would at least check the coil for continuity first (you could have a good coil but bad valve, but one thing at a time).
Running the part number I stumbled on this used part: http://www.ebay.com/itm/like/131636133994?ul_noapp=true&chn=ps&lpid=82 Since it just as old (probably older) than the one you have now, no telling how long it will last. But compared to dealer price you might think of stocking up on this part just in case!
