Accurate Body Measurements - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-26-2013, 10:59 AM   #1
Redeyejedi's Avatar
what is good method for measuring body dimensions?
did a search for specs, and search if someone had posted similar but no luck.
1994 pickup, ext cab 4x4 v6 5sp.
thanks
Redeyejedi is offline   Reply With Quote
Old 03-26-2013, 12:53 PM   #2
Jesse Fullerton's Avatar
Tape measure?
Jesse Fullerton is offline   Reply With Quote
Old 03-26-2013, 03:58 PM   #3
Good measurment equipment can run you more than 1000$. Just exactly what do you need to measure and why?
http://www.autobodytoolmart.com/gaug...ent-c-530.aspx
Or for "measuring tram"
FSM Body dimensions.
http://personal.utulsa.edu/~nathan-b...13bodydime.pdf
Co_94_PU is offline   Reply With Quote
How to Properly Adjust 1st Gen IFS Torsion Bars to Factory Specs (Via the SM) 89fourrunner 86-95 Trucks & 4Runners 3 02-17-2016 07:52 AM
Missing after warm .Help With codes - 99 4runner 3.4 - codes p1300 p0302 p0300 Jayboy74 95.5-2004 Tacomas & 96-2002 4Runners 7 09-18-2015 12:12 PM
How to measure valve lashes without knowing their original order? foampile 03+ 4Runner/GX470, & 05+ Tacomas 0 08-11-2015 01:41 PM
Bent frame reliablity yourrealdad 95.5-2004 Tacomas & 96-2002 4Runners 2 07-21-2015 12:13 PM
Fan Shroud Ordering Help! TURBOrunnerNM 86-95 Trucks & 4Runners 0 07-20-2015 09:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
