Accelerator linkage bushing?
Old 02-22-2014, 04:50 AM
Jay1313g's Avatar
On the truck I am building, the "hook" on the accelerator linkage that mates to the carburetor seems to have a lot of play in the bracket it goes through.
I checked a Toyota parts diagram and found a part number for bushing that is obviously not present in mine.
Can I safely assume I need to order two of these? (The parts manual really just looks like one.)
Thanks,
Jay
Old 02-28-2014, 08:29 AM
cjohnson's Avatar
Not sure where you mean but does this thread help at all?
https://www.yotatech.com/forums/f116...-cable-277908/
The bushing he discusses in this thread was gone in mine. Much more responsive when I fixed that.
Old 02-28-2014, 05:44 PM
Jay1313g's Avatar
Thanks cjohnson, but the part I am talking about is on the other end of the throttle cable. I'm not sure how it worked on the 3.0 engines, but the bracket I'm talking about looks like a hook and mates up to the carburetor on the 22r.
Old 05-12-2021, 04:53 AM
N6Three's Avatar
I was having this issue and I believe the fix is using an eclip or the original retaining clip at the end of the hooked lever’s end after it is inserted into the carbs main lever linkage!!! After lots of frustration, I noticed the notch for a retaining clip at the end of the hooked lever will sometime stick in the carbs receiver/main throttle lever hole causing binding. When it is not jammed in the retaining clip slot, the assembly should feel a lot smoother without using a bushing as OP- and I- initially assumed. Hope this helps .
mwisham
05-26-2021 02:51 PM
Lons81
02-18-2021 08:24 AM
Backforty
09-27-2019 07:31 AM
pavel74
07-10-2011 05:06 AM
nomiss05
07-10-2009 02:39 PM
Quick Reply: Accelerator linkage bushing?
