AC Relay need to be jumped on a 93 Pickup?
I have done an Air Conditioning recharge on the R12 system on my Ford Probe in the past. I have a bunch of R12 that I got from my wife's grandma's garage when she was moving (she asked me to throw it away).
Anyway when I did the recharge of the R12 A/C system on my Probe I had to install a jumper wire to trick the system into running the compressor while filling the system to get enough in . Is there a similar operation to be performed on my 93 Toyota pickup?
In case it matters (which I doubt) it's a 1993 Toyota 4x4 4cyl 22re.
And yes I did search and have been unable to find anything about this part of the process.
There is a jumper that can be installed to bypass the low pressure cutoff switch:
http://www.4crawler.com/4x4/CheapTri...ne_Pix/20.html
Not sure if that applies to recharging the system or not. A Factory Service Manual (FSM) would likely have that information.
Johntom240
7
07-13-2015 12:18 AM
Poncho0206
07-10-2015 06:21 PM
4runner, 93, ac, air, compressor, conditioner, conditioning, jumpering, low, pickup, pressure, relay, switch, toyota, truck
