YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-01-2006, 07:05 PM   #1 (permalink)
AC probs.
The ac has not worked since I bought this 4runner. Its a 93. I have a spare fan switch, I have checked the fuses under the dash (behind the glove box) and also replaced the clay looking relay/fuse under the blower motor. Any one else have any Ideas?
The fan will not blow on any speed??
harley_sr is offline
Sponsored Links
To remove this ad, register today!
Old 09-01-2006, 07:06 PM   #2 (permalink)
86SR522REEFI's Avatar
Send a message via AIM to 86SR522REEFI
your switch is bad
__________________
<(((Mark)))>
1997 4x4Runner
Limited 5-VZE
Auto 134,000 Miles
Quote:
Originally Posted by Leslie Nielsen
I am serious, and don't call me Shirley.
86SR522REEFI is offline
Old 09-01-2006, 07:25 PM   #3 (permalink)
I have 2 spare switches.. I have tried them both..
__________________
91 SA Toyota MC08 w/MC 4.7:1 5:29's Spooled & Locked on 38in TSL's Ohhh and its got a Sunroof!
Old 09-01-2006, 07:27 PM   #4 (permalink)
Now on the origional one, I did see a burnt spot on the plug of the harness, and one of the little fingers on the back of the switch it self. Thats what made me think the switch is bad, but like I said I have 2 spares and neither one is doing the trick.
__________________
Old 09-01-2006, 07:29 PM   #5 (permalink)
The only other thing is my org. switch is Black in color. Now my other 2 are a off white color. The plug is the same, and they have the same prongs.. One came from my 93 truck, and the other came from a runner from a wrecking yard.
__________________
Old 09-01-2006, 07:35 PM   #6 (permalink)
get one from autozone for cheap, and you know its the same thing
__________________
<(((Mark)))>
1997 4x4Runner
Limited 5-VZE
Auto 134,000 Miles
Old 09-01-2006, 07:38 PM   #7 (permalink)
Yeah I will give it a shot tomorrow. Just sux not having AC...
__________________
Old 09-01-2006, 07:40 PM   #8 (permalink)
tell me about it, ive had my truck for almost a year and a half with no ac, im just starting to get the parts together.
__________________
<(((Mark)))>
1997 4x4Runner
Limited 5-VZE
Auto 134,000 Miles
Old 09-04-2006, 09:06 PM   #9 (permalink)
Saint_Berzerker's Avatar
I looked at the FSM schematic for the ac and really the only thing in between the blower switch and the blower is the big honking resistor.
Either that resistor got blown up, or your blower motor is out. I can't really see anything else. Having burn marks though, I'd say that one of those 2 is blown.
If you have a meter, just check the resistance for that resistor. Just see if it's open (very high ohm reading).
Mine blows like crap on everything but all the way up. I took it all apart and cleaned it all up, but didn't help a lot.
__________________
'93 pickup 4x4 22re 5spd
Saint_Berzerker is offline
Old 09-05-2006, 12:00 AM   #10 (permalink)
yota_krazy's Avatar
try banging on the blower motor with a hammer handle or something, sometimes if the blower motor has crapped out that will get it to run temporarily. Otherwise id check the resistor as stated above.
yota_krazy is offline
Old 09-05-2006, 08:52 PM   #11 (permalink)
I found the prob. The owner that had it befor me had taken the 40amp squar fuse out when he mounted a toggle switch to run the fan. I had a friend that had a 4runner that was 1 year newer and I poped his glove box out and saw it... Guess I lucked out on that one
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Alternator Probs HALMAN 95.5-2004 Tacomas & 96-2002 4Runners 10 08-26-2007 07:42 PM
Few headgasket probs ShortyzKustomz 86-95 Trucks & 4Runners 3 03-30-2007 12:45 PM
Shifting Probs 4x4Lamm 95.5-2004 Tacomas & 96-2002 4Runners 13 12-19-2004 08:17 PM
Starter probs????? Help Jesters_taco 95.5-2004 Tacomas & 96-2002 4Runners 1 11-19-2004 05:59 PM
Router probs Churnd Computer Talk 8 09-23-2004 05:44 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
