Ac idle-up VSV, stuck?
Old 12-01-2013, 10:42 AM
pinstripe_chuck's Avatar
I have a 90 PU with 22r. When I turn the AC on, the diaphram pulls and increases the idle as it should but when i turn the AC off it does not release the vacuum to decrease idle. I have to actually pull the hose off of the idle up diaphram before it will return to normal idle. How does the VSV release vacuum once it is turned off?
Old 12-01-2013, 11:14 AM
Punchy's Avatar
You can wd40 the VSV, Also make sure the vacuum hoses are correct, If there backwards it can do that.
Pri$erulz
11-17-2019 08:03 PM
Redeth005
06-28-2018 08:16 PM
Boomer8404
09-24-2015 01:12 PM
andrewtexas123
09-23-2015 07:48 PM
Quick Reply: Ac idle-up VSV, stuck?
