AC idle up mechanism- on board air
Old 09-16-2008, 11:23 PM
Matt16's Avatar
I've nearly fit got my York to fit, and I'm trying to figure out a clever way to have the engine idle up or maintain its idle speed despite the extra load of the belt driven compressor.
There's a wire with a grey plug on the end which hangs down under the intake manifold. I'm wondering if that has anything to do with the AC.
Old 09-16-2008, 11:33 PM
SwampThing's Avatar
Just let it ride. If it bogs down, turn on your AC
Old 09-17-2008, 12:08 AM
Matt16's Avatar
I don't have AC, but the wiring (might) be there.
Old 09-17-2008, 12:17 AM
SwampThing's Avatar
Good point. Well there is a plastic screw on the engine side of the throttle body. If you turn the ac switch ON and adjust that screw, you should be able to adjust the ac on idle speed.
Old 09-17-2008, 12:21 AM
SwampThing's Avatar
Or tap in a relay to the powersteering idle up wire. Think that'd work too (though it is just speculation).
Old 09-28-2008, 07:57 PM
Matt16's Avatar
That could be a possibility.
Ideally, the engine idle goes up to ~2000 rpm if I can swing it. I was thinking of buying the bracket and linkage used to control the throttle for cruise control (allows multiple cabled to control the throttle), then attaching a servo from a model plane which when activated, would open up the throttle a bit.
Old 09-28-2008, 08:24 PM
littlecommando's Avatar
or, you could just change the idle speed. im not entirely sure how to do it, but i know that it is at the end of the throttle cable
Old 11-05-2008, 08:28 PM
86tuning's Avatar
You could install a hand-throttle with a bicycle shifter (think old skool friction thumbshifters not the clicky indexed ones) and attach it to your throttle body at the unused cruise-control spot. Or wire it to the top of the gas pedal.
Old 11-10-2008, 07:23 PM
yotasavg's Avatar
i'm interested in this....bump
Old 11-10-2008, 07:49 PM
Matt16's Avatar
I've realized that you need the throttle linkages from a truck with cruise control.
Old 03-16-2011, 12:20 AM
twistedyota's Avatar
bump
old thread wanted to know what people thought off. bump
Old 03-17-2011, 11:15 PM
BC-Luc's Avatar
I used an electric vacumm selenoid to up my idle. Worked great.
ie, electric vacumm switch controled from inside the cab that opened a larger vacumm switch that allowed metered air into the plenum.
Does that make sense?
Luc
Old 03-18-2011, 04:47 PM
weaselman's Avatar
Luc
do you have a pic? maybe a diagram of how you hooked it up?
Old 03-18-2011, 05:37 PM
JamesD's Avatar
What you can use is off any carburated GM car or truck is the A/C idle up solenoid. Looks like this: http://www.google.com/images?um=1&hl...&aqi=&aql=&oq=
Go to the junk yard to get them.
James
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
sojourner567
07-16-2015 08:52 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: AC idle up mechanism- on board air
