AC Compressor help
AC Compressor help
Hey there what ac compressor come stock in a 1992 3vze toyota pickup??? Was at the junkyard today and the guy said they had to types and to pop the hood and there should be a tag that tells ya but i see nothing. Thanks again and any help is appreciated
Only other way to tell is looking at the fittings on the charge lines. R-12 has thread on fittings (looks like valves on your wheels) and R134a is a quick release like a air hose sort of.
Good Luck!
AC Diagnostics - 93 toyota pickup 3.0
problem - AC compressor will not engage when the i hit the switch. I recently swapped out my 3.0 for a rebuilt and not just trying to get the AC dialed in, will the low pressure switch protect the compressor if there is nothing in the system? id like to ensure the system will run prior to adding the refrigerany (134a). How about the VSV? will this keep the compressor from kicking on or if the VSV is bad will it just keep the engine from kicking up slightly in idle? last question, will the thermistor prevent the compressor from kicking on some how? thanks for all the help . . .
If there is nothing in the system the compressor will not turn on or engage. That's a fail safe if you lose the refrigerant and its oil that you will not burn up the expensive parts. As far as I know anyways, I always charge the system first and try from there.
compressor is good, charged the system and everything kicked on like it should-- shut if off and turned it back on, my dad noticed a sputtering down at the compress, got underneth and found a large hole on the aluminum part of the low pressure line -- will the 4runner system match the 93, 4x4 3.0 V6? i checked my little bros 22re 93 and no dice-- the line ties into the cooling unit differently --any help?
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
coryc85
12-05-2015 08:42 AM
1992, 3vze, ac, check, compressor, compressors, difference, engage, kicking, passing, pickup, pressure, stop, switch, thermistor, toyota
