AC clutch bearing question
Guys,
I have still not found my FSM even with all the boxes unpacked with more to go.
So a newb question.
How to remove ac clutch?
Prefer to do so on the 4rnr as it blows cold.
If anyone has an e-copy of the FSM they don't mind sharing please help a bother out.
Thanks in advance.
So a newb question.
Thanks in advance.
http://personal.utulsa.edu/~nathan-b...12compress.pdf
You want to remove the A/C clutch from the compressor? I don't understand "Prefer to do so on the 4rnr as it blows cold." "Blowing cold" sounds like a good reason to NOT remove the clutch.
That would be an electrical problem not a clutch problem.
The power to the coil is not being shut off.
Like all other things electric I guess a surge could weld the contacts like a starter .
I never took one apart now I am curious just how they do work.
What happens if you just unplug it??
That belt should be by it`s self remove it till you get it fixed..
Depends on the model of compressor some had a snap ring some had bolts in theory it should come off .
In real life most times it is stuck and a puller is needed being careful not to break anything .
Just where you live plays a big part in how bad it is stuck.
the1998sr5
15
07-14-2020 08:35 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
