Absolutely un-funny...Water pump leaking again!!
Old 04-10-2006, 02:25 PM
VA_Yotaman's Avatar
This is unreal. After putting a 2nd water pump on, it is leaking again. I have put water pumps on before, on other vehicles, and never had a problem. This most recent install, I used Ultra Grey Permatex. I let it set up overnight, so it could cure properly. Can anyone give me insight on wether or not I am putting the bolts in the correct position? There are 5 bolts of one variety,and 2 with washers, correct? I believe I am putting them back in the correct places. Would the 91 be any different from the 93 shown in the FSM?
http://personal.utulsa.edu/~nathan-b...09waterpum.pdf
Torque is 14 or 15 ft. lbs. Do you have to do anything special to the studs that hold the water inlet on? I am at a loss. I guess I'll break it down, take off the main timing cover, re-install the radiator, and run it so I can get my eyes exactly on what is happening. Any other way to go about this?
Old 04-10-2006, 02:59 PM
Bassinfool's Avatar
I had the same problem until I put a gasket on it. I know it says you don't need it, but as soon as I put one on, no more leak. I used the gasket (it's just a paper one) and ultra copper sealant on both sides of the gasket. Haven't had a single problem since.
Old 04-10-2006, 03:06 PM
VA_Yotaman's Avatar
OK, I'll give it a try. I still have the paper gasket from the 2nd pump.
Old 04-10-2006, 03:08 PM
4runnermt's Avatar
Use the gasket for sure. I used edelbrocks gaska-cinch and rtv silicone and zero leaks.
Old 04-11-2006, 02:25 PM
coloradodragon's Avatar
You didnt happen to use those "stop-leak" pellets did you? I used to use them for radiator leaks and they worked too good. They plug up the pinhole in my radiator--also plugged up water pump. I guess I learned my lesson trying to do things the easy, cheap way. never again.
Old 04-15-2006, 07:15 AM
dmatter's Avatar
Sure it is'nt the #2 Idler Pulley Assembly? I am Changing mine out this Afternoon. But, My Leak is a Pretty Big One Truck was Fine One Minute Next Minute I had Water All over the Front of the engine. It Was Leaking Higher up then the Water Pump But Leaking all over it.
TURBOrunnerNM
07-22-2015 11:01 AM
icentropy
07-14-2015 10:23 AM
Jonny246
07-12-2015 04:51 AM
cars-guy
07-11-2015 07:51 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Absolutely un-funny...Water pump leaking again!!
