| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
About to embark on a project... quick advice.
__________________
"Battle Wagon" 1992 Extended Cab, 3.0 with KN intake, black steelies, procomp xtreme all terrains, XM radio, kicker 12" sub, cobra 25ltd CB- R.I.P. 09-09-09 New Baby: 1994 Extended Cab, 22re, AC, Cruise, ProComp Extreme All-Terrains, stock radio, 4-Runner Buckets, Manual Hub Conversion. NEW WORK IN PROGRESS!!! |
#2 (permalink) |
just look under the passenger side dash and it might just fall out on you.
But I hope that actually is your problem did you test the circuit first? It may need a blower resistor, switch, or relay.
__________________
Targetnut don't talk about it, just do it! Precision Import Service '93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate |
#3 (permalink) | |
Quote:
Its getting power, fan just ain't be blowin.
__________________
#4 (permalink) | |
Hey, i just finnished this about 2 hours ago...
Ok lets see it's pretty easy to get to on a 1st gen runner, just remove the glove box to give you some extra room to work with. You may also want to pull and test the resistor pack while you are down there, mine was bad it's about 10" away from the motor on the firewall. I also replaced my heater relay. Unbolt three bolts that hold down the motor/fan pull out (it's a tight squeeze) remove fan from motor and put fan on new motor. Next just squeeze the new motor back in and you are good to go (except that my replacement motor didn't fit right so it has a littel rattle) Now if you don't have a 1st gen runner, or a 2nd gen pickup, then i don't know for sure but it seems like they didn't move it far so it should be similar. Let me know if you need anymore help.
__________________
88 4runner 22re Quote:
#5 (permalink) |
Gah.
When I tested the leads at work, they were recieving signal. Now they are not. Wtf. Anyone know what fuse the heater is on?
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| I need quick advice (seriously for once) | fustercluck | Off Topic Talk | 45 | 11-08-2007 03:38 PM |
| Quick advice needed.. | ttr125mar | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 05-31-2005 03:21 PM |
| need quick advice... | northfacer581 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-22-2005 08:51 AM |
| Quick Disconects...need advice | amorphous | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-14-2004 11:51 AM |
| Need advice quick. Please help! | rimpainter.com | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 01-28-2003 01:44 PM |
