A340h automatic transmission
Old 04-28-2010, 11:56 AM
Csull's Avatar
1991 4runner Automatic 4WD 3.0
Dear yota tech
i need your 2 cents
4 wheel drive light keeps flicking on and off when in 2H... transmission was clunking when it shifted into what seemed like gear 2 until i unplugged what appeared to be a very very plugged up vacuum check valve... shifts ok now... but light still comes on and off...
i can elaborate and even add some pictures of anything that would be useful
Old 04-28-2010, 12:02 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Where's this vacuum valve located?
The light could very well just be the indicator switch on the front of the differential getting intermittent contact when it shouldn't be. But, that valve has me questioning things a bit.
Old 04-28-2010, 01:10 PM
Csull's Avatar
the valve is right beside the fuse box under the hood
seen in this picture
Old 04-29-2010, 10:12 AM
Csull's Avatar
bump.
Old 04-29-2010, 11:49 AM
mistergarrett's Avatar
If you unclogged it, try resetting your ECU, If the code comes back..... well you know.
On second thought.. im not sure,, but i didnt think the "4x4" flashed codes.
I google for days before i start a post.
4x4-runner
12-27-2016 01:58 PM
BeMiceElf
10-10-2015 09:40 PM
kelly1450
09-02-2015 12:29 PM
Hugh_Mann
08-31-2015 04:02 AM
Quick Reply: A340h automatic transmission
