YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-29-2008, 07:46 PM   #1 (permalink)
GenXr's Avatar
95 truck bed won't separate from frame
I've unbolted the bed in 8 places, unbolted the fuel filler from the body, removed the tow hitch and bumper but I can not get the bed to budge one bit away from the frame.
Is this common? Does any one have good advice?
Two things I tried, my buddy and I got on each side and tried to pull it up, and the other thing was I put a 2x4 on one of the trusses and tried to jack it up slowly with a floor jack. Neither technique worked.
What else have I forgotten? (I know I need to disconnect the wiring before removing the bed)
GenXr is offline
Sponsored Links
To remove this ad, register today!
Old 08-29-2008, 08:07 PM   #2 (permalink)
JamesD's Avatar
Does this truck have body lift on it?
James
__________________
2nd gen power mirrors for sale http://www.yotatech.com/f109/2nd-gen.../#post50746877
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569
Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/
JamesD is online now
Old 08-29-2008, 08:22 PM   #3 (permalink)
GenXr's Avatar
No, my truck currently does not have a body lift.....although I would like a 4crawler 1" BL.
GenXr is offline
Old 08-29-2008, 08:28 PM   #4 (permalink)
slacker's Avatar
really .... there are only 8 bolts holding it down . fuel filler and wiring , whatever ..
unless the bed silencer pads have dissenegrated , and the bed has rusted to the frame .. it should come off ..
just keep liftin'
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5
MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 08-29-2008, 08:31 PM   #5 (permalink)
scuba's Avatar
Location: Selling turnips on a flatbed truck, I 15N @ 79S
try just putting your jack on top of your tire and go up, the bed itself is pretty heavy so it might take a bit.
But thats the best solution i can think of
Good luck and
__________________
^Say GO DJ..Uh thats my DJ
The Blue Biche
91 4x4 p/u 22re--elbow mod, 500ff's. BFG A/T ta KO's. Smokey the Bear
I Work on my gas tank while smoking a cig...Sue me
Dad- 1999 4runner base 2x4, 2.7, 5speed, 52k, cherry.
Chat with meeee
Quote:
Originally Posted by DailyDrive View Post
I heard jumping on your left foot 3 times and spitting over your right shoulder once would increase your MPG by 10-20%
Pacific Crawlers
UltimateYota
scuba is offline
Old 08-29-2008, 08:53 PM   #6 (permalink)
calisurferdude2000's Avatar
Send a message via Yahoo to calisurferdude2000
Do you have access to a chain hoist? If you do use the tiedowns and some chain to yank it off. That's what I did with my 87.
__________________
'87 Toyota 4x4 w/94 bed Firestone 31's, Rancho RS5000's, Kenwood deck, AISIN hubs
91 4Runner 3.0/5speed, 4x4, 31's
calisurferdude2000 is offline
Old 08-29-2008, 10:18 PM   #7 (permalink)
Get A Bigger Hammer
__________________
'87 4runner
33", five speed, 4.88, arb, 6" of really bad lift.
gte718p is offline
Old 08-29-2008, 10:33 PM   #8 (permalink)
4Crawler's Avatar
Yep, should be just the 8 bed mount bolts (4 on each side) to remove. Maybe just need to jack it up a bit higher. You need to take the weight of the bed off the frame and suspension and thus the whole back end of the truck will lift up. Could be some of the frame brackets have rusted to the bottom of the bed.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-29-2008, 11:04 PM   #9 (permalink)
ocdropzone's Avatar
spray some rust penetrator on the body/bed mounts and let it soak. If Ohio salts their roads like they did when I lived in NY it will take a little time soaking. Try also chaining the truck frame to the floor jack so that when you are lifting against the bed (use a 2x4 or something to spread the load across the bottom of the bed) it does not try to left the whole back side of the truck.
__________________
~Robb
'81 Trekker SR5 B4Runner Build
'89 Tercel Project POS Gas Saver
'05 Camry 'Wife's curb destroyer'
'03 Tahoe Family Truckster/Tow Rig
TREKKER Forum
LINK TO ONLINE FACTORY SERVICE MANUALS
All Toyota Website Search Engine
Wheel Responsibly, Don't screw it up for others...
ocdropzone is offline
Old 08-30-2008, 03:08 AM   #10 (permalink)
kipres's Avatar
did you disconnect the gas tank tube?
kipres is offline
Old 08-30-2008, 06:23 AM   #11 (permalink)
GenXr's Avatar
ok, great advice everyone. I'll try the different techniques this afternoon and report back on what worked.
GenXr is offline
Old 08-30-2008, 06:00 PM   #12 (permalink)
GenXr's Avatar
Success! It took a combination of more PB blaster between the mounts and using a crow bar to pound in between the bed and frame. It finally popped loose.
I've got a lot of work to do to clean up the frame. The main fuel line coming from the tank rusted and spewed fuel everywhere (the main reason I took the bed off).......and now I can't decide between one of Roger's 1" lift or a flat bed!
GenXr is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
removing bed from frame PCE91V64x4 86-95 Trucks & 4Runners 12 07-02-2008 06:47 PM
Need help badly with 84 cab and bed on 90 frame coaldigger 84-85 Trucks & 4Runners 0 05-06-2008 03:46 PM
PA:WTB 79-83 Toyota Truck longbed frame and bed toomanytoyzz Items Wanted 5 06-08-2007 07:34 PM
FREE 82 yota 4wd short bed frame/cab/bed skullver Hot Deals/Free Stuff 5 04-18-2007 04:13 PM
Will long bed fit short bed truck? 83beater Pre 84 Trucks 5 01-10-2006 03:43 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
