95 4x4 4Runner 5 speed swap
Old 10-13-2015, 12:42 AM
shaunt's Avatar
Was just wondering what other parts do I need to complete the swap so far I have the trans, pedal assembly, master, clutch slave, ecu, flywheel, clutch, rear shaft so far any help will be greatly appreciated.
Old 10-14-2015, 12:21 AM
wyoming9's Avatar
Red face
This is one of those things not having the donor vehicle close at hand is a real pain!!
We all forget something
New flywheel bolts ??
The transfer case and new mount
The cross member !!
The means to make a new line for the clutch Hydraulic system plus the rubber line.
I hope your going with all new parts Aisin if possible the other stuff is pure junk as of late.
The shifter boots and covers
The electrical end getting around the neutral safety switch
Like I said a bunch more nickle and dime things causing numerous trips to the auto parts stores and other sources for parts .
Good luck!!!
Old 10-26-2015, 12:32 AM
shaunt's Avatar
Thanks a bunch Wyoming9 it was very helpful
Old 10-26-2015, 12:33 AM
shaunt's Avatar
Originally Posted by wyoming9
This is one of those things not having the donor vehicle close at hand is a real pain!! We all forget something New flywheel bolts ?? The transfer case and new mount The cross member !! The means to make a new line for the clutch Hydraulic system plus the rubber line. I hope your going with all new parts Aisin if possible the other stuff is pure junk as of late. The shifter boots and covers The electrical end getting around the neutral safety switch Like I said a bunch more nickle and dime things causing numerous trips to the auto parts stores and other sources for parts . Good luck!!!
DeathCougar
04-01-2018 11:29 PM
jashoeuh
11-26-2017 07:01 AM
Higbee89
08-27-2015 06:52 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Gevo
07-29-2015 11:15 AM
Quick Reply: 95 4x4 4Runner 5 speed swap
