95 4wd probs
Old 11-23-2011, 12:30 PM
joe wrinkle's Avatar
95 4wd probs
My atomatic runner does not engage in 4wd when i try to drop it into geer. I replaced my cv joints yeterday, when the job was done i took it up a trail and also ran over a log. Has replacing my cv joints, or runing over that log, might of been the cause of knoking somthing loose, or what else might it be; Where do i start??? I can hear a click under the dash.....and when driving 20mphh I can feel a slight rev in the moter when shifted....but now power to front tires and no 4wd light
Old 11-23-2011, 12:31 PM
just bought it and want to learn to diagnose this stuff my self but need some help
Old 11-23-2011, 01:17 PM
hgill's Avatar
an expert should chime in but does your truck have ADD or manual hubs?
If its ADD, then it could be that a vacuum pipe is loose or something. and wire to the ADD actuator.
Old 11-23-2011, 01:21 PM
auto locking hubs
Old 11-23-2011, 01:24 PM
where is the wire to the add acuator??......is it on the front diff.....next to the two vacume lines?.....and the vacume canister under the front right side do I have to take it off to see the hose on the other side??? or is there only one hose
Old 11-23-2011, 04:15 PM
can anyone answer my questions...I would be really gratefull
Old 11-23-2011, 05:44 PM
TNRabbit's Avatar
Vacuum engages the ADD; there's a connector that runs down under the distributor, by the oil pressure sending unit (if 3VZE) & connects to the diff for the light in the dash. Check those. There are TWO vacuum hoses running to the front diff that actuate the ADD.
Old 11-25-2011, 01:30 AM
maniacmotorsports's Avatar
disconnect the vac hose to the dif and run a seperate vac line straight to the diff from a vac scource on the intake, one port at a time, that will bypass solenoids and force the axle to engage. then just put it all back and it should function properly, thats all it took for mine.
Old 11-26-2011, 01:29 PM
benchernif's Avatar
Check all the vacuum hoses - I had this same issue at the end of last winter after replacing 1/2 of all my hoses. I discovered a hose completely disconnected from an actuator. No biggie - just had to plug it back in and it easily engaged again.
Most of the hoses and valves/actuators are on the passenger side of the engine behind the battery, just above the wheel hub. It's a pain the ass to check it all, but you'll get the idea.
Diagram example:
https://www.yotatech.com/attachments...ence-vac-2.jpg
Also, check near your front differential. There are 2 different hoses that plug into the front diff. If those are disconnected you could also be having the same issue.
Best of luck.
Ben
kawazx636
10-06-2021 03:03 PM
bryan34w
12
09-30-2015 02:50 PM
tylermx71
09-29-2015 08:49 PM
Cycles
09-29-2015 06:37 AM
May-39
09-06-2015 01:05 PM
Quick Reply: 95 4wd probs
