95 4Runner - Installing new radio trouble
Old 05-18-2010, 04:10 PM
krazydude's Avatar
I recently attempted at installing a used Alpine stereo into my 95 4Runner, with disastrous results. I am quite certain that I wired the stereo correctly, but I believe I may have blown a hidden fuse (the clock and interior front door lights no longer work, but the cigarette lighter still does...).
The fuses on the driver side are all fine, but is there something I'm missing such as another fuse behind the stereo or improper grounding?
Thanks.
Old 05-18-2010, 04:19 PM
UKMyers's Avatar
Did you check the fuse block under the hood? I forget where the fuse is for that stuff.
Old 05-18-2010, 07:31 PM
krazydude's Avatar
I checked the fuses under the hood and they were all fine.
Old 05-18-2010, 09:46 PM
norcal707's Avatar
check all the fuses one by one.....both inside the car and under the hood.....something like this happend to me on my civic and overlooked one of the fuses, so I checked it twince and found it. and next time, disconnect the ground battery to void this.
Old 05-18-2010, 09:47 PM
norcal707's Avatar
wait....make sure you didnt cut a wire somewhere behind the stereo
Old 05-18-2010, 09:49 PM
iamsuperbleeder's Avatar
and the fuses behind the kick panel on the driver's side?
there's a thread active right now where someone mention their stereo wasn't working, and neither was their horn. they check the horn fuse and sure enough it was blown. replaced the horn fuse, and magically the stereo started working too
Old 05-19-2010, 06:00 AM
Astralplane's Avatar
After looking at the wiring diagram.
http://www.the-roo.com/4runner/Wirin...s/radiopla.pdf
I would say either the 15A Dome fuse is blown or the wiring from the dome fuse to the radio is disconnected.
Old 05-19-2010, 09:42 AM
CHOPER's Avatar
double check the wires
hey i recently intalled a alpine 9881 head unit in my 92 toy aswell. my gauges n tail lights stoped working because i was blowing the fuse because i had one wire the wrong way on the head unit.you can go to....the12volt.com.....just enter ur vehicle and year and it will tell you wich wire is for what coming from the stock harness. my mistake was the ground i accidently wired it to a power source that connected the tail lights. you more than likely have a blown fuse in the driver side kick panel. hope this helps you.
Old 05-19-2010, 09:44 AM
CHOPER's Avatar
http://www.the12volt.com/
Old 01-14-2012, 10:32 AM
sixstringslut's Avatar
Thanks CHOPER, that's what I was looking for.
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: 95 4Runner - Installing new radio trouble
