95 4runner coolant hose identification and help
Old 07-04-2009, 03:20 PM
customdrumfinishes's Avatar
1995 4runner 3.0 2wd
i need these hoses identified / real names and are they dealer items only?
the hardest part i have right now other than hose names is getting this unknown intake hose?
it has a spring clamp on the hoseand i want to replace it. what clamp to use?
i cant use a screw down type no room to tighten it up/my hand is huge i can barley even touch it.
anyone ever replace this hose?
picture below of hose against the firewall i cant get off to easy.
heres a pic of some of the hoses i need named/identified
this hose is gone, i need identified/named
2 pics below shows where ends of hose go
near front of motor
under/near intake
the next pic is another hose, i need it named.indentified
Old 07-04-2009, 03:23 PM
if there is a diagram and name of these hoses i can look a online that would be great
Old 07-04-2009, 03:26 PM
Tubbyfatty's Avatar
How are they going bad weekly? Im pretty sure every part store (napa, autozone, shucks....) will carry these. At least the main ones. Any hose clamp should work. A regular hose clamp.
Also, that last pic, thats not the carb, that would be the throttle body....
Old 07-04-2009, 03:32 PM
toyota4x4907's Avatar
Unless you special ordered a non-North American carbed 3VZ-E or you converted it to a carb, your 3VZ-E is not carb'ed
Old 07-04-2009, 03:54 PM
1 started leaking last week and another today, 1 had a pinhole in it and other dry rotted around hose clamp/spring.truck has never over heated etc just 100* summers here its hard on rubber parts and dry rot is normal here
autozone and advance dont have these hoses at all so no help there at all..
i cant get a normal hose clamp on the hose near the firewall to tight i guess ill re use the old spring clamp and pray it holds.
Old 07-04-2009, 03:56 PM
Also, that last pic, thats not the carb, that would be the throttle body....[/QUOTE]
yes i know that but in need hose help not carb/throttle body identification lol
ill edit the 1st post so its real easy to understand what im asking about
i trying to make this simple and just need the names of the hoses i need to get, thats all i need thanks
Old 07-05-2009, 07:29 AM
jasonbrink's Avatar
Go here: http://www.toyodiy.com/ Type in your VIN & you will have all the diagrams and dealer part numbers (and estimated prices) to identify all your hoses and anything else you will ever need.
Jason
Old 07-05-2009, 09:32 AM
nv4runner's Avatar
I know that A B and C are your heater hoses. I replaced all the hoses back there when I did a head gasket job, and for the most part I just took them down to Napa and had them match the shape, length, and diameter as best as they could since Toyota wanted big $$$ for some of those hoses and would have to special order them anyway. I think there were 8 little water bypass hoses back there.
Old 07-07-2009, 05:35 AM
yeah toyota is the only seller of these hoses.
i Wish someone else sold these, they dont!
had to buy hose c for only 38.10 lol most expensive hose ive ever bought.
the others can wait on replacment lol, thanks for the replys
Old 07-07-2009, 06:59 AM
TNRabbit's Avatar
Colington
03-08-2020 09:51 AM
jakebarrett
07-10-2015 07:15 PM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: 95 4runner coolant hose identification and help
