94 V-6 Transfer Case Help
Old 09-25-2011, 09:09 PM
RRogers's Avatar
I have a 94 SR5 pickup, 3.0 5 speed (r150f). The rear output shaft seal has started leaking. I need to know what tranfer case pickup has so i can replace the seal, and want to replace the bearing while I am at it. Did toyota use more than one type in 94 behind this transmission? i have tried searching for a couple of days now and have not come up with the answer for myself. Any help would be appreciated.
Old 09-26-2011, 03:56 AM
skypilot's Avatar
There were two, You may have the chain drive case. count the bolts on the output housing. If its seven you have the chain drive, and its dealer only. If not Marlin Crawler has all the parts.
Now to go to a gear drive you need an adapter which costs $$$
Old 09-26-2011, 04:20 AM
TNRabbit's Avatar
You have the VF1A chain-type V6 transfer case:
http://www.4x4wire.com/toyota/faq/parts/
Old 09-26-2011, 08:22 AM
RRogers's Avatar
Thank you for the info. That link was very helpful TNRabbit.
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Phantez
09-30-2015 08:24 AM
gentry
09-28-2015 06:16 AM
Quick Reply: 94 V-6 Transfer Case Help
