94 Toyota ecm pinout
Old 10-18-2010, 05:55 PM
Kelly G's Avatar
I have a 94 toyota pickup 3.0 with the code 52. I have tried the relocate to the lift hook with new sensor and pigtail but still get the code. I want to run a new coax to the ecm and wire it in there. Does anyone know what plug and pins go to the knock sensor? Thanks Kelly
Old 10-19-2010, 02:55 PM
Kelly G's Avatar
With all the code 52 problems someone has to know.
Old 10-19-2010, 03:05 PM
scope103's Avatar
Pin 5, connector "B" (dark grey, 16 pins in two rows).
Do you have any reason to believe that relocating the knock sensor (particularly to the lifting eye) would work?
Old 10-19-2010, 05:14 PM
Kelly G's Avatar
The relocation is just temporary until I get the new wire run and get that problem fixed then I will take the intake off and put the sensor where it goes. Thanks
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
crashburnoveride
08-28-2015 09:20 PM
nick b
07-11-2015 04:38 AM
Quick Reply: 94 Toyota ecm pinout
