94 toyo not firing,PLEASE HELP? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-14-2006, 08:36 PM   #1 (permalink)
I just purchased a 1994 toyota pickup with a 22re EFI. The seller said the truck was run about a month ago. After changing the battery i found the engine is not firing. Ipulled the plugs out, checked for fire at plug as well as at the wire itself. ialso remove the wire from the coil and nothing coming out of it either. the rotor and cap look ok also. i checked for voltage going into the coil and there is power on 1 wire. All fuses i have found seem to be ok. thanks for any help,suggestion,or info on diagrams i can get
cgfireman is offline
Old 01-15-2006, 09:34 PM   #2 (permalink)
I would have the local parts store check the ignition mod. if it checks out ok my first guess would be coil.
chopps is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Firing order on a 3.4, Help h7009 95.5-2004 Tacomas & 96-2002 4Runners 12 12-09-2007 12:06 PM
Firing Squad 80W90 86-95 Trucks & 4Runners 2 06-10-2007 02:32 PM
Firing order YotaTwist General Electrical & Lighting Related Topics 1 05-18-2007 07:55 AM
Back firing? Sonofmayhem Pre 84 Trucks 7 11-23-2006 03:17 PM
#1 cylinder not firing dstep012 Maintenance & Repair Archives 2 07-10-2005 02:46 PM
2009 InternetBrands, Inc.
