94 Toy V6 won't start w/o coolant?
Old 10-25-2008, 03:09 PM
jener8tionx's Avatar
I am in the process of doing my water pump/timing belt. I have to wait on a new radiator and tried to start the engine dry just to see if it would turn over. No dice. Is there a sensor keeping it from starting dry?
Old 10-25-2008, 04:05 PM
Marc's Avatar
No. Must be something else.
Does it turn over?
Or turn over and not start?
Old 10-25-2008, 05:01 PM
abecedarian's Avatar
nothing should keep the starter from cranking the engine without the rad and stuff.
check that you've got things like sensors and stuff all plugged in.
Old 10-25-2008, 05:23 PM
turns over just fine....just not starting. I checked the timing marks about 10 times. I even took pictures in case I doubted myself!
Old 10-25-2008, 05:29 PM
....ok just went outside and checked the distributer and I unplugged it to move wires out of the way and didn't push the plug all the way back on!!! Thank you for the input....I will be banging my head against a wall for a bit.
Old 10-25-2008, 05:30 PM
....btw it stated just fine and I ran it for about 10 sec.
LosPatosDelSur
23
03-12-2021 03:08 AM
A2theK
09-30-2016 12:50 PM
rjtrials
08-06-2015 07:25 PM
jbandt
08-03-2015 03:23 PM
Quick Reply: 94 Toy V6 won't start w/o coolant?
