94 runner wont start PLEASE HELP
ok so i have a 94 4runner and it has a v6 automatic 4x4 and its getting no fuel or spark, i looked under the fuse box that has the alternater fuse in it and there is a red/blue wire that has a pigtail on it but it isnt connected to anything, when it died it was running and then bogged down and then died and it hasnt started since, any help would be greatly appreciated, thank you
Are you getting a check engine light when you turn the key to ignition? Not necessarily a flashing one..........although, that would help.......but, does it atleast come on?
yeah well it turns out that wire was the fuel pump power wire and whoever had it before me messed up the fuel line fittins in the back by the tank so i just replaced them all and put it all back together and it fired right up, thanks tho
Team420
01-12-2021 04:57 PM
