94 runner brake light
Old 01-26-2009, 11:44 AM
94x4runner's Avatar
I get a brake light that comes on intermitently when I apply the brakes in the morning. It only stays on for a few seconds and then goes out.
Old 01-26-2009, 12:09 PM
Tubbyfatty's Avatar
brake light comes on when,
The E brake is on
Your low on brake fluid
and i think when your alt is going out.
Check your brake fluid level, that would be a start then check back here for any info.
Old 01-26-2009, 01:17 PM
dntsdad's Avatar
The E brake is on
  • and i think when your alt is going out.
I would say low fluid....curious as to how you would you say his alt is going out??
Old 01-26-2009, 01:28 PM
Matt16's Avatar
My brake light stays on for a couple blocks after I've parked overnight with the e-brake on and its cold out. My fluid is clean and topped up. I worried about it for a while, but now I ignore it. If your brake fluid is in order, I wouldn't worry about it unless it stayed on all day.
Brake light+ battery light is your trucks way of telling you the charging system is not functioning properly. This usually means your alt is on its way out which often means the $10 brushes are worn out (easy fix).
Old 01-26-2009, 01:31 PM
904_runner's Avatar
CHeck your brake pads, your brake fluid, and your e-brake.
Old 01-26-2009, 05:01 PM
Tubbyfatty's Avatar
I say i think because i know that the batt light and brake comes on when your Alt is goin out. But his brake light isjust on. Happened to my ex gf and my friend.
gillesdetrail
11-19-2019 12:56 PM
Aleeex_u
06-05-2016 06:52 PM
Wid
07-01-2015 11:54 AM
YotaGreenhorn
06-27-2015 07:00 AM
ItsAtoyotaLIFE
06-21-2015 11:45 AM
Quick Reply: 94 runner brake light
