| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
94 Runner 3.0 auto tranny hard shift
__________________
River's Father 94 4Runner SR5 Stock 3.0L 3VZE | red | 31 BFG's | rebuild completed 94 Pickup -- Stock 2.4L 22RE | red | 31's BFG's | rebuild 2007 - sold to Guatemala 84 Pickup Stock 2.4L 22R | rust Mercedez E320 -- Stock | champaign | GY's | mint |
#2 (permalink) |
Anyone?
__________________
#3 (permalink) |
Id call AAMCO transmissions and talk to them about it, then set up an appt so they can check it out. If you do need your fluid changed, change the filter as well.
If you do want to flush it, do not go to a juffy lube or something like that. My friend took his 94 gmc 3500 diesel there with the 700R4 tranny, they flushed it hard and messed up everything in it. They did buy him a new tranny tho. If your tranny is low on fluid, id go top it off. I dont know what type of ATF it takes off the top of my head. Look in your owners manual or somewhere on here. Ive always had good business with aamco, when i had my old car (98 chevy lumina) the torque converter was going out and they gave me a free flush and filter, and told me to go back in like a month, but i sold the car before that.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag... |
#4 (permalink) |
Thanks.
__________________
#5 (permalink) |
No problem.
__________________
#6 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Hello Aaron.
In the 200k+ miles on my wife's '92 4rnr the tranny's never been flushed. I always just drain it w/a fresh filter and it's been working beautifully. The only problems I've ever had were related to the speed sensor. Mt. Goat (Dale) has more knowledge on a flush. Might PM him. I always like to use Amsoil synthetic in it, but as far as I know any synthetic ATF that meets the Dex II/III will be good. Amsoil is really, really good, though. As far as your shifting, it being low could cause the hard shift. But, also if the fluid is old. What is the color and odor of the fluid?
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#7 (permalink) |
Thook, thanks for the reply. The oil is still red/pink in color and only has a distinct tranny fluid smell. Don't think it is burned. Having said this, I have not experience with auto trannies, so I am limited in smell factors.
Regarding the change in filter, any advice on whether to use a filter from Toyota or Napa? Assuming it is recommended to use the Toyota filter. Is this a time consuming effort or pretty straight forward? Just drain fluid from plug, break seal along pan with a putty knife, remove pan, remove filter and replace all sound right? A question on a different topic....CV joints and universal joints. Have you replaced either on your wife's runner?
__________________
#8 (permalink) | |
Quote:
__________________
WatermanAtWork - 1995 4Runner SR5 - 1990 Pickup |
#9 (permalink) | |
Quote:
2. Dex III, but I've been using Mobil 1 ATF. They (mobil) makes one that is specially for Aisin trannies, but I haven't tried that one because I've never seen it in a store. 3. Are you checking it with the engine running and hot after going through all the gear selections? If so just add a little bit to bring it up to full. My Taurus shifts hard too and I don't know what it is. I've flushed it with Mobil 1 ATF and have the fluid level correct. It mainly does it when its cold. Here's a good write-up on flushing: http://www.gadgetonline.com/TransFlush.htm
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#10 (permalink) |
Mt_Goat, thanks for the link and the input. Gonna give it a whirl this weekend if I can get a filter from the dealership by then. BTW, I am checking the level after going through the gears while running.
__________________
#11 (permalink) |
I orderd mine here:
https://www.1sttoyotaparts.com/partscat.html Might as well pick up a tube of FIPG for the tranny pan too.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 12-11-2008 at 09:43 AM. |
#12 (permalink) | |||
Quote:
Quote:
Aaron.......wait until that FIPG fully cures overnight before you fill the tranny back up or flush it even. I made the mistake by not doing so (waited only a couple of hours) and now have to re-remove the adapter case pan and reseal. Requires dropping the crossmember. Bleh..... Wish I new more about auto's. I know there's some helpful troubleshooting tips in the FSM. I'll see what I can find. Of course, there's google..... <<smart ass<<
__________________
#13 (permalink) | ||
i've actually had sub par experience with aamco, but they do uphold their warranties, so thats a plus. they rebuilt my f250s tranny twice and it still slipped after a month of use. even with the heavy duty torque converter they installed. honestly it could be mostly ford's fault for putting such a wimpy tranny behind the 7.3
__________________
Olive Drab 1995 4WD regular cab pickup,22re, 33x10.5 BFGs,doetsch tech prerunner shocks, all pro shackles,sway bar delete. Quote:
Quote:
TREAD LIGHTLY |
#14 (permalink) |
Thook, I asked about the CV's and universal joints because I will be replacing the CV boots for sure this weekend as well as the front rotors. I have a nasty rumble in the steering column when I apply the brakes. After looking the FSM over and reading a few threads, it looks pretty straight forward in terms of removing the CV axle and getting both boots on. Anything special about doing this job? Also thinking that one of the UJ's may be failing and might be partly responsible for the hard shift when moving from N to drive. Thoughts?
__________________
#15 (permalink) | |
Hmmmm........yeah, the UJ is a consideration. Worth a check. I've had similar symptoms from my 5spd when I had a UJ seizing up.
Nothing special about the CV's really. I know there's plenty of adequate on YT about doing it, so anything I could add would probably be redundant. However, should you run into anything questionable, I'm willing to help. Wear rubber gloves.....
__________________
#16 (permalink) | |
Here's the FSM troubleshooting for the 340H, though it applies mostly to other auto's, too:
http://personal.utulsa.edu/~nathan-b...30generalt.pdf It may not make much sense unless one knows enough about the unit assembly, but it's a starting point. Check that UJ first and go from there, eh.
__________________
#17 (permalink) | ||
Quote:
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| help please with Hard shifting auto tranny, 22re | trythis | 86-95 Trucks & 4Runners | 3 | 05-08-2007 06:13 PM |
| Auto-Tranny Shifting hard into Drive | Tdubbs05 | 86-95 Trucks & 4Runners | 25 | 03-27-2007 09:12 AM |
| Auto tranny won't shift out of park | petros | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-24-2006 01:56 PM |
| 4 runner auto tranny woes | OBX Fisherman | 86-95 Trucks & 4Runners | 7 | 03-25-2006 06:00 PM |
| How hard would it be to remove/reinstall an auto. trans. on a '94 runner? | gsxrguru | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-27-2005 06:19 PM |
