94 P/U 22re will not start cold. Replaced so many parts
Old 03-09-2011, 01:50 PM
Brick In Hand's Avatar
Ok folks. My son purchased a 94 Toyota 4wd, 22re, 5spd in Nov. 2010. I have been driving it all winter with no problems at all (I live in W.Va.). A few weeks ago it wouldn't start on a cold morning but that evening it fired up immediately without even popping the hood.
I have replaced the in tank fuel pump,filters, rotor button, cold start injector, and the cold start timing switch. I also jumper tested the ECU and it is good. But it still will not start on a cold morning. I can open the hood and allow the sun to hit the engine for 30 mins and it hits on the first crank and away I go.
Also, I can smell gas like it is flooded if I crank it over for a few minutes in the mornings when it won't start. Then when it finaly does try to start (around noon when it warms up) it takes it a while to "catch up" or something and smokes for a few seconds. It runs a little rough while driving until it warms up like it doesn't want to take much throttle or like it will miss when I give it too much throttle.
I replaced the cold start timing switch this morning thinking for sure it would be the fix..my spirits sank when it didn't happen. Fuel is good, spark is good, I haven't chkd timing but that wouldn't be an intermittent problem, would it?
Anyway, I have read so many threads here and have tried many of the suggestions but I wanted a case specific post..so here it is. Thx in advance for your insights.
*EDIT: I forgot to mention it is fuel injected.
Old 03-09-2011, 01:56 PM
sebastianholmes's Avatar
okay you have fuel and you have spark, so youre clearly not getting air. check your IACV
Old 03-09-2011, 02:08 PM
swampfox's Avatar
You might check the temp sending unit for the ecu , if it bad the truck will flood . I had this happen on a chevy I owned.
Old 03-09-2011, 04:06 PM
Lawman65's Avatar
How about your coolant level. If level is too low the sensors won't give an accurate reading to the ECU.
Old 03-09-2011, 05:00 PM
RPlais12's Avatar
Try putting a drop light next to the kick panel where the ECU is located and see if it will start after 30 minutes while its cold. I had a buddy who had to do that because a power wire to the ECU had a touchy connection. A guy had to run him a new wire, Said it was one little strange wire,
Old 03-10-2011, 11:08 AM
scope103's Avatar
You know, you might be getting too much cold start injection. This seems like a long-shot (since you replaced the timer and the injector), but smelling fuel, and having to run it up once it starts, sounds a little like its flooded.
But it might be worth a quick check. When it's cold, crank it for 10 seconds. Pull off the electrical connector to the cold start injector, and try again. If it starts (even if it only runs for 60 seconds), you might be onto something.
Old 03-10-2011, 12:43 PM
The MAN's Avatar
I would look into a bad coolant sensor too.. check the resistance on it... sometimes old sensors "shifts" out of spec and the ECU may think it's 20 degrees when it's really 60, flooding the engine!
Old 03-10-2011, 03:27 PM
he has a lack of air, everythign mentioned up there ^^^ are things that can cause it. test things before you just throw parts at a truck.
Old 03-10-2011, 03:42 PM
The MAN's Avatar
if he has a lack of air, don't you think his face will be turning blue?
like I said... the coolant sensor has a lot to do with how much fuel the ECU decides to use for cold starting... if the sensor is screwed up, the ECU will think it needs more fuel than it needs and the engine gets flooded
even with a bad IAC and everything else is ok, the engine should run if you have crack the throttle open a bit...
Old 03-10-2011, 05:57 PM
Sportsmanphil's Avatar
For kicks and giggles, bump the air intake off the throttle body just a small bit and shoot some starter fluid in there while cranking.
Old 03-11-2011, 01:10 AM
The MAN's Avatar
yes, but he's getting fuel (flooding from what it sounds like)... so I don't think that's going to do much except make things worse
Old 03-11-2011, 01:30 AM
totally a bro
Staff
vital22re's Avatar
I agree with the coolant temp sensor. Check resistance. Pull the plugs and see how they look, I wonder if you have leaky injectors. Lack of air would mean he's got a squirrel in the intake. Iac deals with the idle when hot or cold, not if it runs cold or hot. How does the coolant look? If it hasn't been flushed or replaced in a loooooooong time you could get build up around the sensor causing false readings.
Old 12-03-2011, 10:56 AM
fjfodee's Avatar
Man, I wish the OP would have followed up on this. I'm having the exact same issue.
Yont283
09-23-2022 08:06 PM
the1998sr5
10-19-2016 12:48 PM
voiddweller
19
05-02-2016 09:10 PM
newzingo
06-24-2015 01:50 PM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: 94 P/U 22re will not start cold. Replaced so many parts
