94 4Runner shutting down
Old 04-25-2014, 07:00 PM
rt35's Avatar
My 94 4runner carrying a 22re engine runs for 25 mins then shuts down, after i restart it, it shuts down every 3 to 5 mins. I replaced the igniter, coil,distributer cap, spark plugs, plug wires and the ECT sensor. I've had the ECU tested, no faults there.what could be causing this shut down?
Old 04-25-2014, 10:25 PM
parchisi's Avatar
How does it run during that first 25 minutes?
Old 04-26-2014, 05:38 AM
rt35's Avatar
Hi, parchisi, for the first 25mins the van works fine, no issues at all. By the way, i've also replaced the fuel pump and filter. Could the fuel pressure regulator be causing this?
Old 04-26-2014, 11:42 AM
wyoming9's Avatar
Red face
Just where did you get the replacement coil and igniter.
Coils like to quit when they get hot due to them starting to break down
I am thinking maybe one of the relay coils is going bad Circuit Opening Relay or The EFI
When it shuts off is it abrupt like you turned the ignition off or does it just run out of power to it quits??
I would also check the fuse blocks for any loose fuses or arc marks
All your grounds as well the one for the ECU/ECM on the intake manifold.
How is your Battery if the charging system is not working correct the ECM/ECU will shut off if the voltage drops to low.
Charecter1
11-06-2023 10:08 AM
the1998sr5
15
07-14-2020 08:35 PM
Doug4320
03-24-2018 10:11 PM
Jeffreynmandy
07-18-2015 08:26 AM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: 94 4Runner shutting down
