94 4runner is running rough
Recently I noticed that my engine was making some odd noises when its at low RPM or if I let go of the gas going over 20mph, I start to hear an odd noise that never happened before.
A couple days after when i start the engine cold or warm, in the low RPMs it seems to vibrate the whole car, and it doesnt go away until the RPM is above 1,200.
I decided to start the car this morning with the hood open and noticed that the engine is vibrating alot more then I am use to seeing, so I throttle the gas a little bit until its not shaking as much and let go and it sounds like an engine thats about to run out of gas but not as bad.
Im taking it into a shop soon but I want to see if anyone has any ideas that I can try out instead of overpaying a mechanic for something i might be able to simply fix.
Its the V6 3.0 3VZE engine. Automatic
Peteyg39@hotmail.com
06-26-2015 08:15 AM
