94 4Runner project
Old 01-10-2016, 06:40 AM
mswierse's Avatar
94 4Runner project
Well, I picked up a 2nd Gen 4Runner with a bad knock in the motor. Just pulled it out and everything has gone pretty well so far. I did break one fitting that had 2 vacuum lines going to it and I'm not sure what it is... need to figure that out so I can replace it.
Here are some pics:
Taking the 4Runner home for the first time!
Home safe and sound
The fitting in the back used to have two vacuum lines, bottom one is broke off. Any ideas what that is?
Only thing I broke taking the motor out... hmmm what is it?
Old 01-11-2016, 04:38 PM
justin_4runner's Avatar
http://www.autozone.com/engine-manag...?checkfit=true
autozone has it. its a vacuum ported switch.
Old 01-12-2016, 04:56 AM
maco35's Avatar
I'd try doing this first... https://www.yotatech.com/forums/f116...ix-pics-84460/
Old 01-12-2016, 09:02 AM
mswierse's Avatar
Thanks for the info! I will definitely be fixing it...
Well, now that think about it. While I have the motor out I will likely put headers on it eliminating the EGR and PAIR valves. Can I get rid of more of this crazy vacuum madness?
Old 01-17-2016, 04:23 PM
sphealy's Avatar
Here are some pics:
Home safe and sound
https://www.yotatech.com/forums/f199...thread-266985/
Another option same idea
Old 01-17-2016, 04:58 PM
Chaser Johndoe's Avatar
how far into the rebuild are you? have you thought about the 3.4 swap?
Old 01-17-2016, 05:02 PM
mswierse's Avatar
I am definitely considering it. Looking for motors right now.
Old 01-17-2016, 05:36 PM
i think its worth it. double the power and way less issues.
stangman39
12
06-10-2012 12:42 PM
RMA
12-18-2009 08:38 PM
JimiJams
01-30-2009 11:34 AM
ibornagain
10-13-2008 04:52 PM
Quick Reply: 94 4Runner project
