94 3.slow ARB snorkel help!
Old 11-27-2009, 02:20 PM
Booosted Supra's Avatar
Arrow 94 3.slow ARB snorkel help!
Does anyone have pics of the install to the engine bay? I was able to get the snorkel off of a buddy but the tubing was all lost over time. I researched but most pics are 22re. Soooooooooooooooo if you have a 3VZE with snorkel can you post a pic of the ARB plumbing, I would like to come up with a copy to it and make for a clean install
Old 11-27-2009, 02:28 PM
yoterr's Avatar
no pics..but should just be able to make it out of pvc or something, i made one for my dodge out of 4" pvc
what i started with, 2 45's and a 3' straight and a 4" filter and rubber couplings
what i ended up with, all painted n such (painted with header coating)
Old 11-27-2009, 02:40 PM
tc
tc's Avatar
Curious to see how you shoehorn it in there ...
Old 11-27-2009, 05:02 PM
no 3.0 guys with ARB snorkels on tonight?
Old 11-28-2009, 02:21 PM
anyone? this is ridiculous lol i know you guys are out there
Old 11-28-2009, 02:49 PM
rdhill's Avatar
I have a 3.0 with ARB snorkel. What specific pics are you looking for?
Old 11-28-2009, 04:16 PM
85TurboRunner's Avatar
ARB just supplies the snorkel, it is up to you to figure out how to run it to your intake. At least thats how it works with the 22RE.
Pics of the inner fender plumbing and under the hood if you dont mind, greatly appreciated
Old 11-29-2009, 11:22 AM
I've yet to see a set up like that, jeeps, tacoma's etc come with plumbing... it better for the kind of money they cost
Old 11-29-2009, 11:37 AM
tc
tc's Avatar
Just thought of something - have you called ARB?
They have GREAT customer service, and would probably send instructions with pix, or even sell you the missing parts.
Old 11-29-2009, 12:38 PM
rdhill's Avatar
I would concur with TC. ARB might be a better resource than us. Furthermore you will need the instructions and template that comes with the kit.
For public knowledge's sake the ARB snorkel for the 3.0 is sold with all the necessary plumbing to connect to the bottom side of the air filter box. My snorkel was installed in 5 months ago so it is a recent kit. In a nutshell, the snorkel penetrates the outer fender skin. There is a rubber hose from the snorkel to a cast aluminum 90 degree fitting that is attached to the inner fender wall between the outer and inner skins. The output of the aluminum 90 goes into a hard plastic tube that is sealed and riveted to the intake of the air filter box.
I suspect it will difficult to use a solid hose from the snorkel to the air intake due to the bend radius and the tight quarters in the fender well behind the air box.
Old 11-29-2009, 01:17 PM
bain's Avatar
Id definitely call ARB and get the template and the missing parts. It will be tricky getting a hard tube to fit up in the fender..
this is for a 3.0
Old 11-29-2009, 07:18 PM
thanks for the great info guys! calling ARB in the AM
Old 07-30-2010, 05:35 AM
MoGas's Avatar
....And?
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
choppe777
05-16-2016 08:00 AM
justdifferentials
09-05-2015 06:52 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: 94 3.slow ARB snorkel help!
