94 3.0 wont start
Old 10-11-2009, 09:58 PM
machine23's Avatar
94 3.0 wont start
so i hopped into my runner to move it into my garage to make sure the rotor is pointed at cylinder 1 in tdc...i get the rotor to where i want it, i get everything back together...i try starting it to see how she runs after the adjustment.
and it wont start anymore. just continuous cranking...fuel smell out of the tailpipe...but not starting.
i checked everything at tdc. and all is how it should be. wires are all connected. im at a loss...help me guys
Old 10-12-2009, 05:38 AM
machine23's Avatar
bump-
Old 10-12-2009, 05:46 AM
Team420's Avatar
If it ran before you adjusted the timing, but wont now... timing must be off.
Old 10-12-2009, 06:08 AM
Ardent's Avatar
Is it firing/back firing at all?
All plug wires tight? Do you have spark?
I would check everything on the ignition first.
Old 10-12-2009, 11:37 AM
machine23's Avatar
yea its getting spark. and the timing is good. but i did remove the tps to test it and then put it back in. if the tps was installed incorrectly by me, would that keep the engine from starting?
Old 10-12-2009, 11:55 AM
24Runna's Avatar
I think if the TPS is installed incorrectly it will create a no start situation, though I could be wrong, it could just cause bad idle.
Have you checked all wires you touched? Also are you 100% sure put everything back together correctly? EG: When no. 1 is at compression, the rotor should point to no. 1 on the cap.
Old 10-12-2009, 12:00 PM
yodathespian87's Avatar
If everything is as it was taken apart then it naturally should work. I would double check the timing and make sure its dead on. With my Lexus if it isn't dead on its all down hill from there. Then you say you have fuel, so check spark, then check compression.
Charecter1
11-06-2023 10:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MTLroadierunner
07-15-2015 12:58 PM
Roger Borba II
07-09-2015 05:05 PM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: 94 3.0 wont start
