| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
94' 22re too rich
#2 (permalink) |
Also no CEL untill it loads up to the point it dies.
#3 (permalink) |
I have drove with the cold start injector electrically disconnected and still same symptoms. Drove with O2 sensor disconnected, same symptoms. Drove with TPS disconnected, same symptoms. Timing was set when timing chain service was done. I need to get that timing light back and try checking my timing when this thing is acting up.
#4 (permalink) |
Take your AFM off and test the resistance compared to the factory manual recommendations. This is what was causing me issues (although it was ALL the time instead of off/on) a while back.
__________________
Kyle H Current Yota: 86 4Runner - Daily Beater |
#5 (permalink) | |
what about the coolant temp sencer not for the gauge but for the ecu maybe its bad?
air filter very dirty or cloged? it seams that you have fuel and spark so it will be in the air flow perhaps you have a clog somewhere in the air intake check the box over really good cause the air filter maybe brand new and the box itself has alot of dirt in it getting sucked up to the airfilter so i would look over the air intake itself
__________________
GO TEAM LAZY!! my name is ALLAN yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear Quote:
www.myspace.com/whatsadisplayname |
#6 (permalink) |
AFM tested ok to specs in my haynes manual however the air temperature tested about 20 degrees high which I contributed to my truck being black and setting out in the sun. Air filter is fairly new but I will check air system for obstructions. Read the test procedure for checking coolant temperature sensor, will do that when I get a chance soon. With how sporatic this is (only lasting 10-20 seconds each time) if the cause will test ok unless I can catch it when I am having issues.
#7 (permalink) |
have you tryed to pull the codes yet? that would be my first step...
__________________
91 PU, 4wd, manual, 22re, .30-over, engnbldr RV head and 261 cam, MC 1200lbs clutch, misc LCE, engnbldr, and MC parts and HW, Pacesetter header and exhaust kit, Rancho UCA's , 4Crawler 1" diff and sway bar drop and 1.5" BJ spacers, WabFab 3.5" shackles, 31x10.5 pavement-pounding ATs on ProComp Extreme Alloys, misc SR5 interior goodies swapped in, 1000watt stereo system MySpace |
#8 (permalink) |
Will there be a code if the CEL does not come on? and if so what is the procedure of pulling the codes?
#9 (permalink) |
Yes, there can be a code stored without the light being on. Try this link:
http://www.off-road.com/toyota/tech/codes/index.html
__________________
#10 (permalink) |
Well, you mentioned "no CEL untill it loads up to the point it dies", so reading that and assuming it did come on, the codes should be stored.
The diagnostic proceedure should be the same for my 91 as it is for you 94. Attached to the fuse box under the hood, just behind the battery, there's a little port with "Diagnostic" or something similar (I can't remember for sure) stamped on it. Pop it open. You'll notice the lid portion has a layout of the pins in the diagnostic port. Using a small peice of wire (paperclips don't work many times because many have a plastic coating on them), jump teminals E1 and TE1 together. Now sit in the truck and get ready to count. Turn the key and watch the CEL flash. If it flashes constantly at about half a second incements, that's a normal code and means there are no codes stored. If it flashes a few times, pauses, then flashes some more, then there are codes stored and you need to take note of how many times it flashes. Decoding the flashes isn't that hard. If it flashes once, then pauses for a sec, then flashes 4 more times, then pauses for about twice as long, then that's a code 14. Basically, each flash is a number and each digit is separated by about a secong long pause. Each long pause is pretty much a break, and it will then either flash the same code again, or flash a different sequence if there is more than one code stored. After typing all that, it may have just been easier to reffer you to the FSM...
__________________
#11 (permalink) |
Reads a code 41-TPS which as I noted above I have drove with TPS disconnected and had same symptoms. I believe I will try clearing codes, run for a while and pull the codes again later.
#12 (permalink) |
well, TPS may be bad, or just out of adjustment if you've mess with it and had it off in the past
__________________
#13 (permalink) |
only disconnected TPS electrically. mechanicall it is un-tampered. still has paint mark from original assembly indicating it is in the original location. I wen't off and left my good DMM at work over the weekend so I am going to attempt testing the TPS now with my back-up DMM
#14 (permalink) |
ok, TPS test to specs and e2-IDL opens at about .032" - .033" on the throtle stop screw. Any ideas on testing the coolant temp sensor without a thermometer?
#15 (permalink) |
For $30.00 I may just replace the coolant temp. sensor to rule that out. Odd the truck predictably acts up in a mid temp range while the motor is warming up. have to get this thing running right so I can get rid of it. While replacing brake lines I noticed 4 rather large holes in the frame. Already had to re-attatch a spring hanger and strengthen the frame last year.
#16 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
have you pulled the plugs? if so, how do they look?
have you verified your timing is correct?
__________________
Quote:
Insomnia: it's a way of life.
#17 (permalink) |
timing was set when I did the timing chain service. It was about two months later when this problem statred. All four plugs are black, covered with carbon.
#18 (permalink) | |
when you checked the timing, you shorted the appropriate terminals in the diagnostic connector behind the battery with the engine running correct? when you shorted them, then engine idle speed dropped correct? what is the timing set to?
when was the last valve adjustment? have you pulled the cold start injector out of the manifold and verified it's not leaking? it's possible the O2 is starting to go out and sending slightly wrong signals to the ECU- my experience with the few I've had go bad is that don't go bad suddenly but rather take their time and slowly fade away.
__________________
#19 (permalink) |
yeah, engine did pull down when terminals were shorted on the diagnostics plug. Timing was set to 5 btdc as shown on tag under the hood. Can't tell you when the last valve adjustment was, I have had the truck since 120k. It's first timing service was done at the dealership with about 93k on it. Don't know if they set the valves then or not.
For the O2 sensor I have ran with it unpluged and it had no effects on the motor other than making the CEL come on. I would assume with the O2 unpluged the ECU would switch to some default setting for that input. I have not pulled the cold start injector out to see if it's leaking; I assume run it up to temperature first then pull the injector out? |
#20 (permalink) | ||
Quote:
not having the O2 sensor connected will force the ECU into a fail-safe mode and will cause the engine to run rich. of note, a failing O2 sensor may not trigger a fault with the ECU until it has actually grossly gone bad so there is a range of operation that the O2 will appear to work in but in actuality it is bad. checking the cold start injector should only require pulling it from the manifold and energizing the fuel pump by either turning the key on without starting the engine or jumpering the fuel pump so that it runs.
__________________
#21 (permalink) |
ok, had time tonight to pull the cold start injector and it had no leaks with the key turned on. I don't believe that is the problem however I could not get the truck to start running rich at all tonight but, like I say, it is very tempermantal and some days will run fine others it will act up 3 or 4 times in my 20 min. drive to work. Each occurance only lasting 5 - 10 seconds.
#22 (permalink) |
Abe, you say that an O2 sensor (despite ohming out correctly per FSM) can go bad, but throw no codes. I have an O2 sensor on my 3.0 that I believe is causing it to run rich just as drranch's is doing. Hooked an oscilloscope up to it right at the ECU and can see that the voltage stays at 0.45 volts. Never oscillates over the 1 V range. Is there a safe way to fool the ECU into thinking it needs to run lean, maybe putting in a resistor of some value in place of the O2 sensor? Do you know how many ohms the sensor should be in order to push it between 0.5 V and 1.0 V at the ECU pins? This would perhaps iron out the O2 sensor?
__________________
River's Father 94 4Runner SR5 Stock 3.0L 3VZE | red | 31 BFG's | rebuild completed 94 Pickup -- Stock 2.4L 22RE | red | 31's BFG's | rebuild 2007 - sold to Guatemala 84 Pickup Stock 2.4L 22R | rust Mercedez E320 -- Stock | champaign | GY's | mint |
#23 (permalink) |
I changed my coolant temperature sensor yesterday. Have drove the truck about 40 miles so far and it seems to be fixed. I tested my old sensor and as it heated up the resistance increased instead of decreasing as the specs showed. The $30 fix was better than some of my other options. I want to thank everyone for their input and helping me get this thing straightened out. However I am sad to say this truck will probably be for sale soon. I want more room and more towing capacity.
#24 (permalink) |
Good to hear that you fixed the problem and it was relatively inexpensive. Funny how that little bugger can cause to many driveability/fuel economy problems.
__________________
#25 (permalink) |
Where is the coolant temp sensor located on the 22re's? Does neone have a diagram or a pic?
__________________
1995 22re Toyota Pickup -Pro Comp ES 9000 Shocks -31 x 10.50 Firestone AT's -Grant Steering Wheel -Kenwood EQ -Pioneer Head Unit -Sunpro Tach -Magnaflow XL Turbo Muffler -15x8 Steelies -Marlin HD Clutch -Pro Comp Pre Runner Light Bar To go on:
130w Pro Comp Stainless Steel Lights |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE running rich | corvettelvr73 | 84-85 Trucks & 4Runners | 6 | 04-13-2008 09:13 PM |
| 22RE running rich | yotamanmn | 86-95 Trucks & 4Runners | 9 | 05-12-2007 05:19 PM |
| 22RE running rich | cweich | 86-95 Trucks & 4Runners | 9 | 10-03-2006 11:15 PM |
| 22re running rich | stevrock | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 12-30-2004 12:29 PM |
| 22re running rich | bain | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 11-02-2004 04:16 PM |
