93 toyota wont start
Old 04-19-2009, 07:22 AM
made2win1's Avatar
has spark, fuel, timing right on im baffled
Old 04-19-2009, 07:50 AM
nv4runner's Avatar
Since it sounds like you've checked the Battery, Ignition, and Fuel, you should check for air now. Remove the intake tube at the throttle body to see if it starts. If it doesn't then do a compression check. If compression is low and the intake tube is still off then loosen the exhaust and see if that makes a difference.
Old 04-19-2009, 09:13 AM
abecedarian's Avatar
how can you check the timing if it won't start?
what work's been done to the engine recently?
Old 04-19-2009, 09:34 AM
91Toyota's Avatar
Tried turning it over?
6th Gear
19
12-10-2019 07:31 AM
Crazychris1871
06-27-2016 10:38 AM
vasinvictor
01-20-2016 12:39 PM
Dennis140
06-17-2015 10:37 AM
Quick Reply: 93 toyota wont start
